12-02-2009, 06:05 PM   #1
MX and ME (Super) cases: compatible?
Hi, all:
Quick question: can anyone confirm if the stock case for the ME / ME Super will fit the MX body? I'm in the market for a decent case for an MX but all I see are ME Supers on the 'bay. Thanks!
12-02-2009, 06:48 PM   #2
monochrome's Avatar
I do not believe they are compatible perfectly. I just sold a new-in-box soft case for the MG / MESuper. The package does not include MX as a camera it fits. Boz's website says the MG and MESuper share the MESuper MG Soft Case and the MX uses the MX Soft Case.
MX: Width x Height x Depth 135.8 x 82.5 x 49.3 mm
MESuper: Width x Height x Depth 131.5 x 83 x 49.5 mm
The MESuper case Width dimension is 4+mm shorter - enough that, in my experience, the MX will not fit inside.
12-02-2009, 06:51 PM   #3
gofour3's Avatar
QuoteOriginally posted by gabriel_bc Quote
Hi, all:
I checked a Pentax price list and catalogue. The MX and ME(Super) have their own “soft everyready case”.
However the cases may be close enough in size to fit other bodies.
Phil.
12-03-2009, 01:18 PM   #4
thanks guys. I appreciate the info.
12-03-2009, 02:10 PM   #5
8540tomg's Avatar
As suggested above I suspect the cases are more or less interchangable.
Does anyone really use these cases for anything more than storage?
I got a case for the MX when I purchased the camera in 1982 or so. I didn't use it much as the cover always seemed to get in the way. It hasn't been used at all since I got the MX winder. Pretty much a dust collector now.
Tom G
12-03-2009, 02:16 PM   #6
monochrome's Avatar
QuoteOriginally posted by 8540tomg Quote
Actually, the MX is 4.5mm too wide to fit in the MESuper case. See my post above re measurements obtained from B. Dimitrov.
I use just the bottom (the half case) on film cameras to enhnace my grip of the body. The tops are OK for storage if you keep a lens mounted but I usually remove my lenses and store them separately - and install the K body cap. ONly hassle is removing the half case to change film - and that doesn't happen often enough these days.
12-03-2009, 05:08 PM   #7
I know the location of a very clean MX case in a shop. PM me if you want me to check in on it.
Edit: I called the shop and had them confirm fit to an MX. No go. I probably fits some other M series camera.
12-03-2009, 10:58 PM   #8
fearview's Avatar
i have those camera MX and ME. i try to put the ME in MX case today... it was little loose..
Tom G
can have it for the cost of shipping? mine is already have crack all over it ssurface
12-05-2009, 01:35 PM   #9
131.5 x 83 x 49.5 mm ME Super
135.8 x 82.5 x 49.3 mm MX
4.3 centimetres is equal to 1.69 inches.
They will have to have different cases.
12-05-2009, 02:45 PM   #10
monochrome's Avatar
QuoteOriginally posted by J.Scott Quote
I think you meant Millimeters = .169 inches.
But they still need different cases. When I had an MX it would not fit in an MESuper case.
12-05-2009, 03:11 PM   #11
Well hell then, that does make a helluva lot of difference.
Even though I am Canadian I was schooled on inches and feet. (read - 'old fart')
In millimeters it isn't so much of a difference, is it?
Sorry for the metric confusion.
I'm so embarrassed!
12-05-2009, 06:24 PM   #12
In regards to an MX case that I thought I saw in a local shop. I called and had them try the case on an MX. It did not fit. Too small.
12-05-2009, 10:56 PM   #13
Ratmagiclady's Avatar
Were the MX cases still made of leather?
I wonder if many had the old Canon naugahide disease, some early versions of the fake leathers were nice for a long time, then suddenly began disintegrating in ugly ways in the early Nineties.
mx
For Sale - Sold: Super-Multi-Coated TAKUMAR 1:3.5/28 with Hood and Cases (Worldwide) Curbster54 Sold Items 1 07-11-2010 02:27 PM
For Sale - Sold: Super Takumar 28/3.5 with caps, hood, cases pingflood Sold Items 6 01-02-2009 08:18 AM
For Sale - Sold: Super-Multi-Coated Takumar 28/3.5 w/ Hood - Orig. Cases / Caps...(m42 screwmou heliphoto Sold Items 11 11-24-2008 04:48 PM
Are these lenses compatible with K100D Super? Morbo Pentax SLR Lens Discussion 6 11-13-2008 05:56 PM
All times are GMT -7. The time now is 07:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
