Originally posted by monochrome Go to the linked website and look at the photos. If you think about how the lens mount looks (and the camera body mount), the flanges mate, then the lens turns about 1/4 CW turn to lock. When you depress the release the lens rotates about 1/4 CCW and pulls out. I would bet the pin is JUST sticking on the edge of the body mount flange, preventing the lens from rotating enough to clear the flange.
The feeler gauge might work.
Originally posted by troyz Don't force anything!!!!!!
I doubt this is a Ricoh pin issue -- it could be a damaged (or improperly engaged) aperture coupling lever.
Best to let a repair shop sort this out, and if necessary, sacrifice the teleconverter to save the body.
thx guys!
I will try the feeler gauge 1st - unfortunately since I no longer tune-up my own cars due to electronic ignition I don't have a feeler gauge set in my toolbox anymore. Have to wait till I get to work tomorrow and borrow one from the shop guys.
Failing the feeler gauge, well... I'm willing to sacrifice the TC if need be as troyz suggests- I was intending to use it as a K/A extension tube anyways. How do I go about doing that? Also, your guess that it may be due an improperly engaged aperture coupling lever might be right. I recall messing with the lever - what does this improper engagement look like? I can open the back and look while on "B" at the back of the lens.
