02-01-2010, 01:43 PM   #1
K2 Stuck Mirror Issue
I purchased a K2 at a yard sale in Wellfleet, MA (mostly because it has a giant, awesome-looking telephoto on it), and it's got this irritating problem: the mirror sticks in the closed position after depressing the shutter release button, blocking the viewfinder and preventing any subsequent shots. When taking the lens off, I can manually pull the mirror down into position via a small metal tab on the left-hand side, but it just "sticks" again the next time the shutter is depressed.
1. I found a link to an SM for this camera, but it was terrible quality and unusable. Does anyone know of/have a better SM or exploded view image so I can get the mirror box out and lube it?
2. I think (based on my learning this afternoon at Google University) that this is a common problem. Does anyone know someone who can fix it for me for less than the cost of the federal deficit?
Thanks for your input and suggestion.
02-01-2010, 02:08 PM   #2
Ratmagiclady's Avatar
It's been on the Cape. And with a long lens like that, probably on the marshes. I'd suspect sticky mirror foam first. Then lube.
We know a really good and reasonably-priced service guy here, you know, with all the stuff. Might be worth your while to have him CLA that ol' gal.
02-01-2010, 05:41 PM   #3
gofour3's Avatar
QuoteOriginally posted by winstonthorne Quote
I would also suggest a CLA by Eric, as the camera has most likely never been serviced.
Have you tried moving the ASA ring, it can also be a problem and get stuck.
A good CLA will also fix this issue and adjust the meter.
It’s a great camera and you will enjoy it, but only after it is working as designed!!
Phil.
02-01-2010, 07:57 PM   #4
QuoteOriginally posted by gofour3 Quote
+1
02-02-2010, 06:37 AM   #5
QuoteOriginally posted by ChrisPlatt Quote
The K2 has mirror lockup, often used with long telephotos. Make sure this feature is not enabled.
You can find a free .PDF copy of the manual here: Pentax USA website
Chris
The mirror lock is not engaged - actually, when the feature is enabled, the mirror sits flush up against the top of the box; when the mirror lock is off it "floats" about 3mm lower and wiggles around. Definitely something rotten in the state of Denmark.
The floating issue also leans me away from sticky foam...bah. It's a sweet-looking camera. I hope I can get it fixed!
02-04-2010, 10:35 PM   #6
Lens Buying Addict
monochrome's Avatar
Eric Hendrickson (referenced above) has CLA'ed my K2 and K2DMD. Both work as new. Recommended.
Visit his website for pricing and policies.
k2, mirror, position, shutter, sm
Help: Program Plus Stuck Mirror CGJung Pentax Film SLR Discussion 17 02-11-2013 10:05 PM
mirror stuck up on a program plus newpentaxman Pentax Film SLR Discussion 9 07-01-2011 08:43 PM
mirror stuck in pz-70 ralfo Pentax Film SLR Discussion 0 10-28-2009 01:58 PM
Spotmatic F mirror stuck drewdlephone Pentax Film SLR Discussion 11 06-25-2009 09:48 PM
ZX-5n Stuck Mirror Question TimB Pentax Film SLR Discussion 2 03-07-2009 04:50 PM
All times are GMT -7. The time now is 05:27 AM. | See also: NikonForums.com, part of our network of photo forums!
