04-15-2010, 10:24 AM   #16
keyser's Avatar
Well, that's normal. The way the K mount works is to provide a linkage which informs the camera how many stops of light will be lost at the set aperture Vs wide open (when metering is done). With this setup, the camera doesn't need to know what the aperture actually is.
I believe that the A series electronically communicates the lens aperture and provides a linear mechanism for stopping the lens to an exact aperture - previous to the A series, this linkage was non-linear.
Of course, this only works if the lens is set to A. Otherwise it resorts to working like an M series lens. (no electronic info on aperture). That's not to say it won't work properly with your camera though... if it has the mechanical linkage to indicate the #stops loss of light, you should be fine.
04-16-2010, 03:25 PM   #17
Portland Pete's Avatar
QuoteOriginally posted by noblepa Quote
I'm pretty sure that ALL the Pentax AF film cameras can control the aperture from the body. I know that my SF-1 can, and, if you don't count the ME-F, its Pentax' first AF camera. My ZX-60 will ONLY support lenses that can be controlled from the body. If you mount a non-A lens or move the aperture ring off the "A" setting, the top LCD flashes "F--" at you.
In Shutter Priority or full auto mode, this is true. Where the PZ-1 beats out the others is in the ability to manually select an aperture. The thumb wheel will allow you to use the lenses without an aperture ring in Aperture Priority or HyperManual/HyperProgram.
04-16-2010, 06:11 PM   #18
Lowell Goudge's Avatar
QuoteOriginally posted by Portland Pete Quote
Yeah, but there is one really big weakness of the PZ-1 that you experience when you step backwards from all the top of the line DSLRS.
You take your shot, and then instinctively wait staring at the back of the camera for an image to appear.
the camera hadnles so much like the *istD, K10D, K20D, and K7D that you forget that it takes several hours for the image to develop (once you get to the processor)
04-18-2010, 09:07 PM   #19
Good point! I'm hesitant to admit that I have done that when switching back from my K10D.
04-18-2010, 09:34 PM   #20
I'm pretty sure that ALL the Pentax AF film cameras can control the aperture from the body. ....
I had MZ-5n. I don't remember it can control aperture from the body.
04-21-2010, 12:33 AM   #21
fs999's Avatar
The *ist is the most recent AF film camera, the smallest also !
film
A film SLR feels better than a digital SLR ? spystyle Pentax Film SLR Discussion 114 11-08-2014 01:54 PM
Using digital SLR and film SLR side by side dugrant153 Photographic Technique 12 07-30-2010 12:00 PM
Newbie SLR film and film develop qestion winglik Pentax Film SLR Discussion 11 06-15-2009 03:13 AM
Which film SLR is right for me? Isaac314 Pentax Film SLR Discussion 11 12-30-2008 10:59 AM
Suggestion Change name of Film SLR and/or SLR Lens sub-forums clawhammer Site Suggestions and Help 4 07-31-2008 06:55 AM
All times are GMT -7. The time now is 04:23 AM. | See also: NikonForums.com, part of our network of photo forums!
