04-22-2010, 08:33 AM   #1
Fixing the flash on Z-1p?
Hi all
I recently decided to step away from digital a bit and went and got a (P)Z-1p on ebay. Camera is okay but: the flash doesn't pop up! I can pull it up manually but it'll be loose and not stay up all the way. I know this has always been a weak spot on the Z-1p....
I also have my old Z-1 which works but is pretty bashed up, the mirror's stuck and the glass (plastic, actually) in the finder has come unstuck and is bobbing around.
Does anybody know a way of fixing the flash without wrecking the camera? Would really appreciate any help for a dyi fix as I love this camera!
Alex
04-22-2010, 02:37 PM   #2
The Z-1 is definitely a great camera. I'd take it to a repair shop if I were you- it's probably a simple matter but would require a professional.
04-22-2010, 03:23 PM   #3
wlachan's Avatar
The flash is spring loaded and held by a piece of plastic at one end. It broke. Just drill a hole and fix a brass rod in with epoxy glue. If it ain't broken, just hook the spring back.
04-22-2010, 03:34 PM   #4
Gashog's Avatar
+1 ^
I had an EI2000 that did the same thing. A lot harder to fix then yours but I was able to get it working like new.
04-22-2010, 04:55 PM   #5
I just made a small wedge I use to hold the flash up. Just two pieces of plastic model sprue glued together. Works just fine.
04-23-2010, 09:38 AM   #6
Thanks all. Wlachan, I took out about 14 screws before I decided I didn't know what I was doing.... Could you tell me how to take the cover off or is it really complicated?
04-23-2010, 01:06 PM   #7
wlachan's Avatar
QuoteOriginally posted by phosphoro Quote
Pop up the flash and remove 2 screws (1 on each side), then you might "squeeze" and pull the flash cover off carefully as there is a tiny plastic clip on each side. Now you should have access to the spring. If possible, you might also remove the entire top but you must be careful not to touch anything inside. The top will come off clean w/o any wire attached. Good luck.
12-31-2010, 07:52 AM   #8
Does anyone know how to fix this problem on an MZ5/N/3 body? Mine had been fine until very recently, then it half-popped up a couple of times and now there is no spring resistance at all.
I can see two screws on the underside of the flash assembly and two more on small metal support bars to the inside. I can see that part of the assembly goes down into the top of the body on the shutter speed dial side and fear the soring may be down there.
12-31-2010, 09:25 AM   #9
QuoteOriginally posted by mzsaunders Quote
Alan is the expert here. Go to his web site and you'll see what can be done.
As mentioned in the other thread, I am going to fix the two Achilles heels of MZ-5N. I have a mini lathe and will custom machine the metal parts for the pop up flash mechanism to replace the flimsy plastics.
01-01-2011, 09:02 PM   #10
Ratmagiclady's Avatar
Actually, someone just recently bumped a thread with the how to do that job on the MZ-5 type bodies. I haven't bothered to with mine, though: pop up flash and film aren't a combination I tend to want to use a lot, (Hec, I forget the thing's there. ) But you can really just make a spring to stick in there with a little piece of cardboard or almost anything. It doesn't take a lot of force.
Tsk. Thought I'd bookmarked that thread. I'll see if I can find it and bump it.
camera, flash
Fixing her hair mr tibbs Monthly Photo Contests 0 01-09-2010 08:33 PM
Fixing a negative jzietman Digital Processing, Software, and Printing 33 10-21-2009 01:26 PM
Fixing a shadow on a face jqjones Digital Processing, Software, and Printing 11 08-15-2009 01:46 PM
fixing signature oatman911 Site Suggestions and Help 3 06-25-2009 09:00 AM
Fixing Times Venturi Pentax Film SLR Discussion 11 05-04-2009 02:20 PM
All times are GMT -7. The time now is 11:09 AM. | See also: NikonForums.com, part of our network of photo forums!
