Adorama Clamp-MiniTriPod $5
Posted By: Docrwm, 08-31-2012, 09:44 AM
Adorama Clamp-Pod - Table Top Tripod with Clamp-Large 4003
$5 plus shipping (mine was $3.95) and most of their Clamp-Pods run $30+
Larger version of Model 1 TPCPS Opens to 2-1/2", this may be used as a clamp, or as a table tripod. Two legs, recessed into the base, simply screw in to provide stable support. Height: 6"
08-31-2012, 01:09 PM   #2
macTak's Avatar
Anyone know if this would be strong enough for the K-5 with a normal prime?
08-31-2012, 01:21 PM   #3
Docrwm's Avatar
QuoteOriginally posted by macTak Quote
One of the reviewers said:
"This is an must have clamp-on pod. Have had mine for 25+ years, and used it w/my heavy Konica SLR"
Which is part of why I ordered one.
08-31-2012, 01:25 PM   #4
LaurenOE's Avatar
I tried one of those years ago. Not very high quality. IMHO.
I recommend this combo...which can use your existing tripod head.
Manfrotto 208 3/8" Head Mounting Plate with Lock Screws 208
Manfrotto 035 Super Clamp without Stud 035 B&H Photo Video
08-31-2012, 01:28 PM   #5
Docrwm's Avatar
QuoteOriginally posted by LaurenOE Quote
Thanks. $43.81 for the two together plus shipping. If the $5 model proves to be too flimsy I may well go your route. Thanks.
08-31-2012, 01:30 PM   #6
LaurenOE's Avatar
QuoteOriginally posted by Docrwm Quote
If you were in Orlando, I'd find the old one I have and give it to you.
08-31-2012, 01:36 PM   #7
Docrwm's Avatar
Generous of you, thanks. Mine is on its way and if it turns out to be less than I need I will probably go with your suggestion because the Manfrotto clamp can accept a variety of inserts so it would be useful for an off-camera flash, a reflector, etc. in addition to the camera itself with the insert you pointed out.
09-10-2012, 01:57 PM   #8
Docrwm's Avatar
It arrived today - you were right. It is adequate to hold and position an off camera flash but not sufficient to hold, safely IMHO, a dSLR + lens. I did find the Manfrotto listed as a package deal for a bit less -
Manfrotto 035RL Super Clamp with 2908 Standard Stud - $27
Amazon.com: Manfrotto 035RL Super Clamp with 2908 Standard Stud - Replaces 2900 (Black): Camera & Photo
09-10-2012, 02:20 PM   #9
LaurenOE's Avatar
No problem. I get no ego for being "right", unless you are my husband, and we are arguing.
F.Y.I. - The package deal you have in your link above is for the 1/4-20 stud, not the 3/8-16. If you use just the stud, it's not as good as the "mounting plate" for an existing tripod head.
The Manfrotto part(s) that I recommend with that clamp is...
Amazon.com: Manfrotto 208 3/8-Inch Mounting Plate for Super Clamp: Electronics
or
Amazon.com: Manfrotto 208HEX 3/8-Inch Camera Mounting Platform Adapter (Silver): Electronics
It's too bad you're not in Orlando, as I could easily lend you what you need.
09-10-2012, 02:23 PM   #10
LaurenOE's Avatar
I recommend the 208 vs the 208HEX, but they functionally do the same thing. Although the 208HEX is only designed for the clamp, the 208 can be used in other stand/flash devices. The benefit to the 208HEX is that the recess in the clamp is a hex too, so that it acts to stabilize anything that is screwed into the 208HEX.
I have both the 208 and 208HEX.
adorama, pentax deals, table, tripod
For Sale - Sold: Kirk 1.75" QR Clamp with Bubble Level twokatmew Sold Items 3 08-26-2012 09:40 AM
STUD weight load of Manfrotto Super Clamp goldenarrow Ask B&H Photo! 2 03-04-2012 11:41 PM
STUD weight load of Manfrotto Super Clamp goldenarrow Photographic Technique 8 03-04-2012 11:39 PM
For Sale - Sold: Macro Rail with QR Clamp + Slik Tabletop Tripod aegisphan Sold Items 4 09-27-2011 07:19 PM
For Sale - Sold: RRS BH-55 Ball Head and LR Clamp (US/CAN) materialsguy Sold Items 3 03-20-2011 05:51 PM
All times are GMT -7. The time now is 01:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
