Originally posted by Wingincamera I down loaded and installed Perfect Effects 8 to work with Lightroom 5. I used it on some raw files that also had been processed in Lightroom 5 and didn't noticed much difference. But when I tried to move the file back into Lightroom it couldn't find LR, I had to manually search for it. After that I was doing some other things in Photoshop and discovered that the program started locking up light it was running out of memory, but that wasn't the case. I tried everything I could think of, nothing work. I finally un-installed Perfect Effects, rebooted, but that did not solved the memory problem in Photoshop. Last thing was to install the last backup of the C drive made the week before. Now everything works as before, and goodbye to Perfect Effects.
Moral of the story, make sure you do regular backups, it can sure come in handy.
No doubt you need a serious computer to run perfect effects... that means both a powerful 4-8 core CPU with lots of memory (like 16GB) and a very decent video card, too.
What do you mean "when I tried to move the file back into Lightroom it couldn't find LR, I had to manually search for it?"
When I use perfect effects, it makes a copy of any original file so no original files are ever touched.
