Adorama Sony Memory Card Sale
Posted By: Adam, 09-22-2014, 02:51 PM
Some nice deals are currently to be had on Sony memory cards at Adorama. Pick the size and speed that you need!
: Buy or Learn at Adorama
Sony 16GB Class 10 UHS-I High Speed microSD Card (Two Pack) $17.90
Sony 64GB microSDXC U-3 High Speed UHS-I Memory Card (Two Pack) $121.90
Sony 16GB microSD U-1 High Speed UHS-I Memory Card (Two Pack) $31.90
Sony 128GB SDXC Class 10 UHS-1 Memory Card - (Two Pack) $134.90
Sony 16GB Class 10, SDHC UHS-1 Memory Card, 94 Mb/s Read Speed, 45 Mb/s Write Speed (Two Pack) $29.95
Sony 128GB Class 10, SDXC UHS-1 U3 Memory Card, 94 MB/s Read Speed (Two Pack) $179.90
Sony 32GB Class 10, SDHC UHS-1 Memory Card, 94 MB/s Read Speed (Two Pack) $56.95
Sony 32GB Class 10 UHS1 High Speed microSD Card (Two Pack) $29.90
Sony 64GB microSDXC Class 10 UHS-1 Memory Card with microSD Adapter (Two Pack) $63.90
Sony 32GB UHS1 R40 Class 10 High Speed SDHC Memory Card (Two Pack) $27.90
Sony 32GB microSD U-1 High Speed UHS-I Memory Card (Two Pack) $55.90
Sony 64GB Class 10, SDXC UHS-1 Memory Card, 94 MB/s Read Speed (Two Pack) $107.90
Sony 64GB SDXC Class 10 UHS-1 Memory Card (Two Pack) $58.90
Sony 16GB UHS1 R40 Class 10 High Speed SDHC Memory Card (Two Pack) $16.90
10-13-2014, 05:08 PM   #2
I would post a critique on these cards very cheap, with some Pentax cameras.
I've always used one of these cards (Sony 16GB Class 10 Secure Digital UHS-1 94MB / s), it's always worked out well on the K20 and K-5II, no problem.
When I put in the K-3, in the first slot, it's all ok, but in the second slot, the camera gives me "read error" or "can not be formatted."
I tried to format with pc but not solved the problem.
Got a good scare, already broken the second slot?
Then I tried with some cards of another brand again in the second slot, and everything still works fine.
I did a search on the web to see if others had the same problem, and I found in differents reviews of Amazon.co.uk, the same sony card has many problems with different pentax cameras.
Just to inform you, maybe it is better to spend a little more, but have a product that does not make problems
10-13-2014, 06:05 PM   #3
Mine in my K30 blew away my SanDisk Ultra. I have the 16GB and is awesome for my k5ii and k30.
10-13-2014, 06:15 PM - 1 Like   #4
JinDesu's Avatar
For everyone's benefit, all their class 10/94mbps read cards are 45mbps write.
10-14-2014, 04:53 AM   #6
noelpolar's Avatar
Anybody want to go half each on a pair of the 128s?
I want one to use as a back up each day when on holiday.....put it in the second slot of my K3 each night and back up the days photo's from the 16s or 32s that I use as my primay card(s)....
10-15-2014, 09:48 AM   #7
lawjie's Avatar
https://www.pentaxforums.com/forums/151-pentax-k-30-k-50/239808-newbie-needs-help-k30.html
Not only Sony, Lexar doesn't work as well on K-30.
10-15-2014, 10:40 AM   #8
csa
csa's Avatar
So what SD cards are recommended to work well in Pentax cameras?
I'm buying a new one for a K10D coming in, soon.
10-15-2014, 10:42 AM   #9
crewl1's Avatar
Can't go wrong with Sandisk, but make sure the firmware in the older camera will support newer cards.
SDHC probably is OK, SDXC may not be supported.
10-15-2014, 11:21 AM   #10
csa
csa's Avatar
I currently have a Sandisk 16GB SDHC Ultra SD card class 10, I assume if formatted in camera this would be ok?
Most of the Sandisks I see online are class 4, these ok?
10-15-2014, 11:37 AM   #11
I am using a TRANSCEND micro SDHC Class 10 UHS - 600x Ultimate 32 GB with adapter and it works fine with the three cameras I own , K20, K- 5II and k -3... I've never had a problem.
---------- Post added 10-15-14 at 08:50 PM ----------
QuoteOriginally posted by csa Quote
format in camera, that's fine, but does not delete data, delete only the FAT, File Allocation Table ... for a full format to delete sensitive data, you can do on your computer and use the slow formatting instead of quick format
10-15-2014, 02:54 PM - 1 Like   #12
csa
csa's Avatar
Thanks for that information! I'm now formatting the card in the computer.
10-15-2014, 04:09 PM   #13
Here you can find a free and specific tool to format the sd card.
https://www.sdcard.org/downloads/formatter_4/
10-15-2014, 06:33 PM - 1 Like   #14
csa
csa's Avatar
Thanks for that link!
The information given on these forums are fantastic!
10-16-2014, 08:49 AM - 1 Like   #15
crewl1's Avatar
I currently have a Sandisk 16GB SDHC Ultra SD card class 10, I assume if formatted in camera this would be ok? Most of the Sandisks I see online are class 4, these ok?
That should work but I don't have a K-10D anymore to test. On this page you can get the latest firmware that supports SDHC if it is not loaded on your camera.
Latest K10D Firmware Update : Software Downloads | RICOH IMAGING
32gb, camera, card, class, data, format, mb/s, memory, microsd, pack, pentax deals, sdhc, sony, uhs-1
Memory Card Error with Sony 32GB SDHC Class 10 neiliosis Pentax K-01 60 01-15-2015 02:37 PM
Adorama memory card sale. Which one??? MD Optofonik Pentax Price Watch 16 09-01-2014 09:10 AM
Sony 94Mb/s memory card: $12.49 Adam Pentax Price Watch 10 05-05-2014 04:19 AM
Adorama Lexar card sale Adam Pentax Price Watch 11 04-04-2014 07:31 AM
Sony 32GB UHS1 R40 Class 10 High Speed SDHC/SDXC Memory Card 19.95$ @ Adorama Weevil Pentax Price Watch 3 03-21-2013 01:13 PM
All times are GMT -7. The time now is 09:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
