I asked the member and he gave permission that I upload the profile. He made it for K-5IIs, I think, but it should work equally well on all 16MP Pentax cameras, and probably others as well. He used the Adobe Lens Profile Creator. The problem with my specific copy of the Samyang 14mm is that it is slightly decentered, so the CA is not uniform, but is stronger on one side than the other. But the profile works well for distortion and vignetting.
To install, just download the attachment, unzip the file, put it in the lens profiles folder (Its in your Personal folder\AppData\Roaming\Adobe\CameraRaw\LensProfiles\1.0 , at least on modern Windows, not sure about other OS, feel free to gugl it). Then open Lightroom, Develop a photo, Lens Corrections, choose Profile, check Enable Profile Corrections, in the Make drop down menu select Pentax, find Rokinon 14mm. And now its applied to the photo!
You can thank John for making this profile
And please post your thoughts if you try it! Here or in the Samyang lens club
