Originally posted by stormtech is the bottom just a rubber foot or does it also have a spike?
It's just a little rubber foot. It works OK, but it's not great in mud, as I have often found.
But if it's muddy, I can rest the foot of the small monopod on the front of my boot.
I have a 2nd tall monopod with a larger spiked foot and a tilt head for when I need something taller, stronger and that works better in soft dirt. But 90% of the time I go out in the field I use the small monopod.
Originally posted by stormtech I am trying to figure out how one uses a monopod
You can use them as walking sticks as you suggested. Alternately, there are also walking sticks and shooting sticks available that work as monopods. This little Manfrotto probably isn't ideal as a walking stick, however, as the lower part of it is a little bit 'light duty' and unsuitable for taking too much weight.
The height of this Manfrotto isn't ideal, as fully extended it does not reach my eye level, so I have to crouch if I want to work high. But sometimes I can find something to put under the monopod in the field - some timber, a camera bag etc - to boost the height if I need it. But if you are shooting low, crouched or sitting down, the limited max height is not an issue.
I don't use a head on the Manfrotto. I just lean the monopod up and down itself as needed. It's usable enough if you only need a limited range of motion up/down, like for sports. But on my larger monopod I do have a small tilt head, which is handy if i need to shoot something high, for example, like birds, for extended periods.
