Originally posted by BrianR More room to position lights will be a win, no?
Perhaps. For me, the flash is not in the hotshoe, but usually remains physically attached to the camera, so the position of the lighting is fixed. (It usually looks something like
this or
that.) You're right that perhaps with someone/something else entirely holding the flash, having even more working distance could be an advantage. You might even be able to pull off a two-lights setup...
Quote: What kind of working distance are you getting with your 180mm + raynox 250?
Just measured it: at infinity focus, working distance is 12cm, image is 17mm (1.4:1); at MFD, working distance is 7.5cm, and the image is 8.5mm (2.8:1) . For working near 3:1, getting 7.5cm of working distance is actually pretty good. For instance, my Vivitar 105mm coupled with a Raynox MSN-202 (a much stronger diopter) gives me a comparable 9mm image, but just 3.5cm of working distance (at infinity focus). I'd much rather use 180mm+DCR250 than 105mm+MSN202 if I need up to around 3:1. I also believe the DoF is better with the longer setup, but haven't rigorously tested that. To compare, a coupled reversed lens set-up should give approximately 4.5cm of working distance.
Now, even 7.5cm is not
huge, so the critter is usually perfectly aware of the camera's presence, especially on a frontal shot. Approach is still key...
Originally posted by noelpolar you guys just need a DA 10-17.... $300
I definitely need a 10-17! I've hovered over the buy button several times. The 10-17mm actually does about 0.4:1 and is really not a bad close-up lens! Thomas Shahan has posted some excellent shots done with the 10-17mm (
example). It allows one to show much more of the environment because of the wide perspective. You should put a short extension tube on and try to get to 1:1!
It's the total polar opposite of the 200mm F/4.
That being said, even assuming your shot is not cropped and our dragonflies are of comparable sizes (I don't think they are), the shot you posted is at best about 1/4 of the magnification of the dragonfly back I posted upthread. Great shot though, and point well taken that you don't need super long lenses to do interesting shots of small critters.
