Have this flash and also the AF360fgzii and
a P-TTL ProMaster 7500EDF (updated firmware, and works very well after that)
a P-TTL
Yongnuo 585EX for $79 at BH and slightly cheaper at
Adorama
If you don't need WR and HSS then you should seriously consider the newer YongNuo 585EX. It is impressive for the price. AFXXXfgzii versions don't have a built in bounce card on them and I sorely miss it. You can stick a visiting card to serve the purpose but hey for that price I might as well have it built in. Also thoroughly check your copy of this flash when you get it. My flash (AF540fgzii) when it was new failed to fire at times at full power and I could not explain why and when. I also have the old 540 and that works very well and has a bounce card along with the diffuser albeit has a slower recharge times than the new version.
