Originally posted by Wild Mark The part would need to be manufactured - this requires the acquisition of the right glass type (if this is known). Then the glass needs to be machined. I am doing this at the moment for a K28/2 internal element - the search for the person who could even do this was hard enough let alone the glass.
At best, the element can be removed, polished, recoated then re-inserted. Imagine a cost of about $1000 for that then you have some idea of the starting point. The above commentary applies if the polishing is unable to sort the fungal 'etching' out.
I guess you would also need to do a new coating, possibly of lower quality than the SMC, right?
Looking at it, I don't think the fungus is bad and should easily clean up. The SMC coatings are relatively resilient, not as bad as say, the east German Pentacon coatings that come off you just look at them the wrong way. In the description it says that the fungus is not accessible. So either the lens is glued together or the lens group is in a tube that's glued together. Too risky for that sum of money.
