Dedicated lens hood of the DA 55-300
Posted By: RKKS08, 06-02-2021, 11:30 AM
On German eBay there is an offer for a clone (?) of the Pentax PH-RGB 58mm, which they say is dedicated for the DA 55-300mm. The lens hood is Hongkong made, but sent from a location within Germany. Price including shipping would be about $ 5.-
They have just a view items on stock, so probably someone imported a couple of them to sell them locally.
PH-RBG 58mm Gegenlichtblende Schwarz für Pentax SMC-DA 55-300mm f/4-5.8 ED | eBay
My question is now: would the hood also fit to the FA 100-300 (there was never a dedicated Pentax for this lens). The FA has also a 58mm filter thread (but probably the DA offers a bayonet for the shade?).
Anyone who has the DA and the FA and has tried to use the DA hood on the FA?
06-02-2021, 01:38 PM - 1 Like   #2
ramseybuckeye's Avatar
QuoteOriginally posted by RKKS08 Quote
The dedicated hood for both versions of the FA 100-300 is RH-A58, according to the Forums reviews. Further research shows it is a screw on rubber hood.
06-02-2021, 07:13 PM   #3
THoog's Avatar
The PH-RBG attaches to bayonet lugs on the DA 55-300mm. The FA 100-300 does not have those bayonet lugs.
For my FA 100-300 f/4.7-5.8, I adapted a cheap copy of the PH-RBG to work with the lug ring from a Matin "reversible" lens hood. The Matin hood came in two parts: a ring to screw into the filter threads of the lens, and the hood, which could lock onto the bayonet lugs on the ring in either forward or reverse position. The bayonet lugs just happened to be the same diameter as the PH-RBG. The only change I had to make to the PH-RBG was gluing a couple tiny pieces of plastic to the bayonet socket so that it would lock in place. Unfortunately, the Matin hoods seem to be unavailable now. There are a number of cheap "reversible petal" lens hoods available on eBay, that use a similar two-part design. I don't know whether the lug rings from those hoods would work with the PH-RBG.
06-02-2021, 08:21 PM   #4
i_trax's Avatar
I have both lenses and both hoods.
DA hood is reversible and bayonet type.
The FA is screw in type and not reversible.
So they are not interchangeable.
You can get a "copy" of rubber collapsible 58mm hood for FA , there are hundreds available on eBay, and cheap.
The Chinese copy of PH-RGB is well made and cheap.
55-300mm, 58mm, coupon, da, ebay, fa, hood, lens, lens hood, pentax, pentax deals, savings
55-200, 55-200 WR, 55-300, 55-300 PLM, etc, which telezoom I should get? Bui Pentax SLR Lens Discussion 67 06-25-2018 08:15 PM
For Sale - Sold: My Best P/KA-mt Tokina AT-X 100-300 / 4 SD Lens with Dedicated Hood and Case in Box fwcetus Sold Items 6 12-14-2017 11:46 AM
For Sale - Sold: My Best F* 300 / 4.5 Lens with Dedicated Tripod Mount and Special Dedicated Case fwcetus Sold Items 4 11-02-2017 08:15 AM
For Sale - Sold: EXC+++ A 20/2.8 w/ Dedicated MH-RB Hood (w/ hood case) & HD-100 Hard Lens Case fwcetus Sold Items 7 12-31-2015 04:36 PM
All times are GMT -7. The time now is 04:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
