As a naive beginner, I purchased a few flangeless, generic M42 adapters and had few difficulties with them. I remove the spring & leave them permanently on the lens.
A number of posters have not had this experience with generics and imply all knock-off M42 adapters are junk & only genuine Pentax adapters should be considered. They are simple devices and I found the conflicting user experiences hard to understand so decided try to identify critical differences.
All my non-pentax brand adapters are chrome plated brass and are well built. Usually they cost about $13-$15 delivered. I remove the spring & leave them on my m42 lenses. The only trouble I've ever had is if too much force is used when mounting, they will occasionally over-rotate*. I measured everything & could find no obvious dimensional faults.
Finally I purchased a Pentax Brand adapter for a direct comparison so I could reconcile the conflicting experiences. I could find no material or dimensionally significant differences between the branded adapter and the knock-offs.
What then is the critical difference?
I removed the spring, put the Pentax adapter on the camera and could NOT get it to over-rotate, so I looked closely at the adapter. It turns out that the ends of the knock- off's ears all have fillets while the ear ends flanking the spring of the Pentax brand are finished square as shown in the following photo: (Pentax left, knock-off right):
I squared off the ear ends flanking the spring location on the knock-off & the over-rotation problem went away!
In the interest of completeness, the ears on my three kinds of knock offs are not quite as long circumference-wise as the Pentax adapter's and the ear edges are chamfered, but these differences seem to have no functional effect.
My advice is if you are going to get one adapter and don't like modifying things, get the Pentax brand. If you are going to get many adapters to leave on lenses, consider the knock-off's for about 1/2 the cost each. For a total of three adapters the knock-off's will save you only about $45-50 total but are easy to modify if you so desire.
Dave
*The over-rotation problem is not a serious difficulty in the first place, especially if one drills a hole in the mount for the locking pin to secure the lens' position.
