After reading many posts about the Demb Flip It! I got interested in this style of flash diffuser. I had made a couple of DIY bounce cards and they worked well, but they didn't last in my crowded bag. The foamie material would tear and get a little dirty.
Looking around ebay I saw this diffuser. The first time I saw it, it was more than the price of the Demb Flip it! Jr. so I wasn't interested. About a week ago I came across a
vendor selling the diffuser for $14.56 and free shipping, so bit on the hook.
The flash diffuser arrived a couple of days ago and I've played with it a little, so I thought I would post a review. I don't know how long the $14.56 will last.
The diffuser is mounted on the flash with elastic. It can be mounted on the back or to the side of the flash head. The elastic strip has velcro on the ends to create a loop, large or small enough, for a number of flashes. It measures 7.5 by 3/4 inches in its relaxed position. The vendor lists compatibility with the following flashes:
- Nikon SB-800, SB-600, SB-80DX, SB28, SB26, SB25, SB24
- Canon 580EX, 550EX, 540EZ, 430EX, 420EX, 380EX, 430EZ
- Metz 40MZ2, 54MZ3
- Minolta 5600hs, 5400xi/hx, 5200i, 3600
- Olympus FL-40, FL-50, G40
- Sony HVL-F1000, HVL-F32X
- Sigma EF-500DG Super, ST
- Nissin 360TW, 360TXP, PZ400-C-N-M
- Sunpak 2000DZ, 266D, MZ440AF
- Tumax 988
- Vivitar 2500, 273, 3500, 850AF
The issue with elastic is that over time it loses its elasticity. The elastic on this unit is user replaceable. Under the rubber grip pad of the mount are two small Philips head wood/metal screws that screw into a plastic plate that holds the elastic in place. As it is user replaceable, the elastic can be replaced at any length if it is found to be too long or too short.
The back plate that holds the elastic can be seen to the left in the following photo. The two protrusions are for the screws to screw into. This vendor is selling the unit for US $28.99 with free shipping
The unit I bought comes with the silver and gold stickers not stuck on the second white plastic plate. Getting the sticker's paper backing off was a pain. I'm not very good with stickering things. I ended up with bubbles and with the stickers not on the plate in exactly the right position. I think if I had of taken more time I could have done a little better, but once stuck that's it. Take your time and smooth out the bubbles as you go if this is going to bother you.
After finishing the stickers, you have three plates, white, translucent, and the gold/silver one. I suppose you could split the stickers, creating one white/gold and one white/silver, as well. This didn't occur to me when I was applying the stickers, however.
The unit, with the plate, weights about 2-3 oz. I would be surprised if a flash head could not support this. The bounce area when the plate is in the holder is about 4.5 inches by 4.5 inches.
The plates simply slide into the side of the holder and can be changed with the diffuser mounted on the flash and the flash mounted on the camera. The plates aren't square and have a rounder edge on two sides so you do have to pay attention when slipping them into the mount. The head is able to rotate 360 degrees, left to right, and 180 degrees, front to back.
As the unit has so much freedom of movement, it is possible to have half of the flash bouncing up, and half hitting the diffuser and going towards a wall, to the left or right, as well. I think this is at least one function of the
Presslite Vertex.
It is possible to flip the diffuser mount so that it is in front of the flash head, and the flash is shooting through the diffuser. This gives me the idea for creating some mount plates for gels. I'm also planning some half translucent half silver/gold Mylar plates as well. The plates are the same thickness as flexible cutting boards, two for $3 at the kitchen store, so experimenting is going to easy and cheap.
My favorite plate right now is the translucent one. Most of the light goes up to be bounced off the ceiling/wall, but some is reflected forward for a bit of fill light. The others I'm going to need to practice with a bit.
The unit comes in a nice case that measures about 3/4 x 5.5 x 8.5 inches with the diffuser and plates in it. There are two pockets to store the plates, one in each pocket and one in the mount in the main compartment. There is also a smaller pocket to the side that can be used to store eight AA batteries. The main compartment for storing the head looks like it could hold two units if needed.
I bought an Omni-bounce for its size, but I think I can carry this one just as easily. Speaking of, I can use the Omni-bounce with this diffuser as well. I'm just not sure if there is any reason to.
For the price I'm happy enough to have bought a second one. I would have liked not to have to bother with the stickers, but I'll get over it.
Thank you
Russell
