07-21-2009, 07:48 AM   #1
cheekygeek's Avatar
Turn a TI Graphing Calulator into an Intervalometer
Instructables.com is one of the coolest sites on the interweb, but this particular one is just ingenius. It seems that some TI graphing calculators have a 2.5mm data port (and cable). As you know, this is also the size of the remote plug on the Pentax DSLRs. A simple program entered into the calculator is all you need to turn it into an intervalometer for your Pentax.
Turn a TI Graphing Calculator into an Intervalometer and Create Time Lapse Videos
The instructions above are for the TI-83 Plus model (which still brings pretty good money on eBay). Luckily, I found that the TI-82 also has the same data port and is available much cheaper. I got one with a set of fresh AAA batteries & the data cable for $15 (including shipping).
The program code is slightly different, but provides the same functionality:
Code:
: Prompt A
: While 1
: For (H,1,A,1)
: End
: Send(A)
: End
07-21-2009, 04:44 PM   #2
Flacosaurio's Avatar
Well, this is just great.... I'm an HP49G guy, so no TI for me.
I was thinking of asking some friends to do the circuitry for me....
07-21-2009, 05:16 PM   #3
I did this with my old TI-85 calculator when I had my K100D. Unfortunately a bit of wind and an unsecured tripod while using said solution ended in sadness. I now have a K20D, but the limit of 99 frames using the internal intervalometer is so limiting. Unfortunately my Ti-85 has died, so it's either off to eBay to replace it or to get a "real" intervalometer.
Here's my post about using the TI-85 as an intervalometer:
Time-Lapse Photography with a TI-85 Graphing Calculator | Geeked Info
A couple of the resulting time lapses taken with my K100D:
Last edited by edrabbit; 07-21-2009 at 05:23 PM. Reason: added links to time lapses
07-21-2009, 08:17 PM   #4
cheekygeek's Avatar
QuoteOriginally posted by Flacosaurio Quote
There's an instructable for that too (alas, in Spanish)
Turn-a-HP49G-Graphing-Calculator-into-an-Intervalomet for Canon Eos
Just to get your mind juiced up for some time lapse work, here's a time lapse of an incredible supercell near Valentine, Nebraska (USA) from about a week ago. The photographer is Roger Hill, a Colorado-based storm chaser and storm tour operator.
Enjoy: YouTube - July 13, 2009 AMAZING Supercell Time Lapse
03-19-2010, 01:32 PM   #5
Nachodog's Avatar
I just found the above program for the TI-83 on the instructables.com site.
I played around with it and wasn't crazy about the simplistic nature of the program. I tweaked it up a bit and this is what I came up with:
Code:
1. Press [PRGM] button. Select 'New'. Give the program a name (Ex. Camera).
2. Input the program below.
3. Functions 'Prompt', 'While', 'For(', 'End' and 'Send(' can be found by
pressing the [PRGM] button. The -> is added by pressing the [STO->] button.
:Disp "Enter Time"
:Disp "Interval (Sec):"
:Prompt I
:Disp "How Many Frames?"
:Prompt N
:I*790->I
:0->C
:Send(I)
:While C<N-1
:C+1->C
:For(H,1,I,1)
:End
:Send(I)
:End
Gonna keep working on it. Might post an update in a bit.
I changed the programming a bit. The '790' scales the time interval to be close to seconds. I also added a 'Send' function before the loop so that it releases the shutter right away instead of waiting one cycle. You can still interrupt the program before it reaches the set number of frames by pressing the [ON] button.
I'm pretty happy with the tweaked program. I'm gonna look into setting up my calculator with a constant electricity source.
03-19-2010, 03:07 PM   #6
Nachodog's Avatar
Hmm... been playing around a little bit, and I really don't like using the 'For(' command as a timer. I'm getting really erratic results. I looked around the net a bit, and it seems as though the TI-84+ has a built in timer that looks like it would keep better time.
I'll have to find myself one of them to try it out.
03-19-2010, 04:25 PM   #7
Jodokast96's Avatar
Wow, a reason to dust mine off. Can't wait to give this a shot.
03-19-2010, 05:32 PM   #8
Jodokast96's Avatar
Ok, in this line:
I*790->I
how do you input "->"?
03-19-2010, 06:15 PM   #9
never thought of doing this...but no reason I should not be able to use my HP48SX's IR port to do the same thing. Great one more thing for my "list"....
heck I would think one should be able to write something to do long exposures as well as time lapse stuff...might be a gawd send for ND shooters. Enter the filter strength, the info for the filterless expsoure values and have the program crunch the numbers and take it from there. Or have the option to just enter the exposure length.
Now, I REALLY wanna do it...next month, maybe.
03-19-2010, 06:29 PM   #10
Nachodog's Avatar
QuoteOriginally posted by Jodokast96 Quote
Ok, in this line:
I*790->I
Just above the [ON] button is the [STO->] button. It stores the value into the variable.
03-19-2010, 06:34 PM   #11
Nachodog's Avatar
One thing about this program though... the "timer" is really a function that's run over and over and over a few hundred times. It's dependant on the processor and how fast it can go through a loop. As a result, it's not very accurate. Luckily it's consistent, but not accurate. I found that time intervals below 4 seconds tended to be slow and intervals above 4 was fast.
I think that the "timer" is also dependant on how fresh your batteries are. This is why I really want to get my hands on a Ti-84 Plus or Silver because it has a real timer function.
Also, responding to brecklundin, I was thinking the same thing. There must be a way to keep the shutter open. I'll take a look when I get some time.
I've found that this site had good reference material on Ti-Basic: TI-Basic Developer: TI-Basic Developer Home: TI-83/84/+/SE
I've also tried a variation that allowed me to get intervals closer to 1 second.
03-21-2010, 09:25 PM   #12
MoiVous's Avatar
I've been fiddling with this on my daughters TI83+ - and note a few inconsistencies:
  • trigger voltage (3.3v) is high, and drops to 0 for the trigger event! This seems ok for short time intervals, but not so good for long ones - hmmmmm.
  • time calibration - it varies a bit again due to batteries
However, I've had a play with the program to make it a touch more user friendly and find a For loop calibration value that is reasonably accurate.
(note that -> is the Sto function):
I've included comments preceded by a // (Delphi programmer....) which should be removed if you type this in
Code:
240->Z    // Basic calibration value when you start
Lbl ME // the Menu section - function buttons Window Zoom and Trace are used
ClrHome
Disp " Camera"
Disp " Intervalometer"
Disp ""
Disp " Options"
Output(6,7,"Cal=")
Output(6,11,Z)
Output(8,2,"Start")
Output(7,8,"Adj")
Output(8,12,"Exit")
Repeat Ans
getKey->A
End
If A=12
Goto IV
If A=14
Goto X
If A=13
Goto C
Goto ME
Lbl C // This is the calibration function
ClrHome
Disp " calibration"
Disp ""
Disp "Any key to start"
Repeat getKey
End
Disp "Wait 60 sec...."
Disp "Any key to STOP"
0->Z
Repeat getKey // loop over this till the user presses a key - hopefully at 60 sec
Z+1->Z
End
Z/60->Z // the number of interations in 1 secont
Goto ME
Lbl IV // the intervalometer
ClrHome
Disp " --------------"
Input "Interval(sec)?",I // time between frames
Input "Frames ?",N // number of frames
ClrHome
Disp " Intervalometer" // tell the user what to do
Disp "With camera off"
Disp "connect camera"
Disp "and TI calc"
Disp ""
Repeat getKey
End
ClrHome
Disp "INTERVALOMETER" // tell the user what is going on
Disp "--------------"
Output(3,1,N)
Output(3,4," frames at")
Output(4,1,"1 per ")
Output(4,7,I)
Output(4,11,"sec")
I*Z->I
0->C
10000->D
Output(6,2,"Click 1")
Send(D) // send signal
While C<N // frames counter
C+1->C
0->Y
For(H,1,I,1) // apply delay
Y+1->Y
End
Output(6,8,C+1) // tell the user what frame
Send(D) // and trigger again
End
Output(7,1,"Complete")
Output(8,1,"")
Disp ""
Disp ""
Disp ""
Disp ""
Goto ME // back to the main menu
Lbl X
ClrHome
There are some useful tools on the TI website, including a programming tool that lets you write the code on your PC - as long as you have the connector to transfer it!
For those that do, the compiled version is attached.
Enjoy
File Type: zip INTERVAL.zip (658 Bytes, 187 views)
03-21-2010, 10:11 PM   #13
Nachodog's Avatar
Hey Chris, that's awesome! I'm definitely going to try out your program when I get a chance.
Just a quick couple of questions though:
1. Will the values set in the calibration section remain in memory (cached) or does it need to be run every session? (Genius idea btw)
2. Also could you explain the reasoning for connecting the camera after the program has started?
3. Can you also explain why you set D to 10000? Is it just a dummy variable or does the 10000 have some significance?
4. Lastly, I can't figure out what the Y variable does. Looks like a counter of some sort, but the C variable seems to hold that job.
Sorry for all the questions. I'm not a programmer at all (do a bit of html and php and did a very little in college) but I really would like to know what the program does every step of the way.
Thanks again!
Edit: One more thing... I can recognize a couple of my lines surviving your modification and that you changed the While condition back to 'C<N' from my 'C<N-1'. I had originally done that because with the initial 'Send' command, the 'C<N' condition would give me one too many frames. Can you comment on your decision to change it back?
03-21-2010, 10:25 PM   #14
MoiVous's Avatar
QuoteOriginally posted by Nachodog Quote
Thanks Alex!
Not yet - though I've just read that you can store a variable in one of the graphics storage variables and read it back - but it slows it down a touch. I'll try and implement it next time around.
Just the electronics geek in me. With 3.3v on the output pins, why risk it? If someone want to correct me please do - I'm happy to eat humble pie
This is my attempt to make sure that the value in the Send has no effect. I've had inconsistent results on the trigger event. This seems to help along with fresh batteries. I'm looking into Assembly Language control of the port instead (this is actually a Zilog Z80 - for those that remember CP/M!!)
Now thats a bit subtle. Y is there to provide a small delay in the loop in the same way that when the calibration phase is storing a number. There are clock cycles for every event, and storing values uses some too. So try and repeat the event.
Thanks again!
Hope that answers most of your questions.
BTW, anyone with a TI84 or better doesn't need the calibration phase as there is a timer command in TIbasic. That would be better than this attempt.
Cheers
03-22-2010, 03:46 PM   #15
MoiVous's Avatar
Update to TI83+ code
After some more playing I noted a problem with long delays vs short delays in time. It seems that for times under 2 seconds it will skip a trigger (at least on my K200d).
So after some more measurements with a multimeter and some fiddling with the code I worked out that the Send(D) variable needs to be sufficiently large and composed of binary 1 (I chose a very large value) and it needs to be sent twice for longer delays as a single trigger has to short a duration.
So here's the new code - it sends 2 triggers for times over 2 seconds, and 1 trigger for times under that. The value of the sent number is (2^32 - 1) - ie 32 1s so the trigger stays at zero for longer.
The elegant solution would be to do some assembler coding......but no time!
Once again, the Sto command is replace with ->
Code:
240->Z
Lbl ME
ClrHome
Disp " Camera"
Disp ""
Disp " Options"
Output(6,7,"Cal=")
Output(6,11,Z)
Output(8,3,"Go")
Output(8,8,"Adj")
Output(8,12,"Exit")
Repeat Ans
getKey->A
End
If A=12
Goto IV
If A=14
Goto X
If A=13
Goto C
Goto ME
Lbl C
ClrHome
Disp " Calibration"
Disp ""
Disp "and WAIT 60 sec"
Repeat getKey
End
0->Z
Repeat getKey
Z+1->Z
End
Z/60->Z
Goto ME
Lbl IV
ClrHome
Input "Frames ?",N
ClrHome
Disp "and TI calc"
Disp ""
Repeat getKey
End
ClrHome
Output(3,1,N)
Output(4,7,I)
Output(4,11,"sec")
I*Z->I
0->C
4294967295->D
Send(D)
If I/Z>2
Send(D)
While C<N-1
C+1->C
0->Y
For(H,1,I,1)
Y+1->Y
End
Output(6,8,C+1)
Send(D)
If I/Z>2
Send(D)
End
Output(8,1,"")
Disp ""
Disp ""
Disp ""
Disp ""
Goto ME
Lbl X
ClrHome
I've also attached the 8XP file in a ZIP for those who don't want to type it on on the calculator.
Alex - I restored the C<N-1 in the While loop as it adds the extra frame as you say. Just a typing oversight on my part......
Cheers
File Type: zip INTERVAL.zip (677 Bytes, 210 views)
cable, calculator, data, intervalometer, pentax, port, program, ti, tripod
pentax k-x infrared intervalometer, anyone tried this one? Thanatos Pentax DSLR Discussion 8 10-28-2010 06:46 AM
Intervalometer for k200d lurchlarson Pentax Camera and Field Accessories 5 03-01-2010 08:59 PM
Timer remote control (intervalometer) for K7 Torva Pentax Camera and Field Accessories 4 01-09-2010 06:31 PM
To turn right or to turn left spura Pentax SLR Lens Discussion 14 04-15-2009 11:29 AM
K20D intervalometer dosdan Photographic Technique 17 04-14-2009 09:42 PM
All times are GMT -7. The time now is 01:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
