I just acquired a new flash diffuser:
A close-up photo:
The diffuser comes from half of a 11"X14" sheet of plastic canvas.
The plastic canvas is available at craft or fabric stores. Mine is from Micheals, $0.40 a sheet that can make 2 diffusers.
Notes:
1. The light loss is between 2/3 to 1 stop.
2. The plastic canvas also comes in solid white. But the light loss is too much, 2 1/3 stops.
3. With the flash in A mode and the diffuser attached, the head of the flash has to be tilted at least 30 degrees. Otherwise the light reflected from the diffuser hits the flash's light sensor, resulting in underexposure. There is no metering problem with p-TTL or TTL mode.
