Bill - no electrical interface at all on the Kx
, which is why I had to use the program remote to drive the infrared one. You can set the camera to focus before shooting in infrared remote mode, if needed. If you could see it like I see it, you would not think it looks professional though! I call most of my DIY stuff Franken-whatever as was always cackhanded and getting worse with age.
Andrew, thanks for the tip, but my remote only holds the shutter open for about 1/2 a second so I have to use option #1. I have had a go with using it this evening with the moon. Worked fine, but I actually it is so bright I only need 30 seconds or less, so am making do with my mechanical remote. I need to fiddle with a way of holding all the wires and bits in place with the Frankenremote. It needs a few bits of blutack and an elastic band or two.
