07-31-2010, 06:43 PM - 1 Like   #1
Class A's Avatar
JPEG quality settings often too high?
Jeffrey Friedl has created an interesting page entitled "An Analysis of Lightroom JPEG Export Quality Settings".
His examples demonstrate how well JPEG compression works below 100% levels. Towards the 100% end of the quality scale, with many images there is a considerable increase in file size with very marginal to no increase in visual precision.
Although he discusses JPEG compression in the context of Lightroom JPEG export settings, the examples are very interesting on their own.
07-31-2010, 08:58 PM   #2
Thanks for posting that. I wish Adobe would have explained that in the export window.
07-31-2010, 11:50 PM   #3
I certainly can't tell the difference among JPGs saved at 92, 95 and 98 but always saved higher than needed hoping it would help if had to go back and edit/resave. Guess thats an experiment for another night. Two copies of one shot, saved at 90 and 98 quality. Then open and resave each at that quality as copy1, copy2, copy3 checking the size as an indication that they really are being compressed differently. Now do the 2 copy3 versions still look exactly alike as the originals did? We have experts that could answer that but its more instructive to do it myself.
Thanks for the article post!
08-01-2010, 06:24 AM   #4
JPG compression levels can make a big difference to file size and yet can have little apparent impact on the way a image looks? Hold the front page!
But seriously, duh. Anyone who has ever saved a JPG before in their whole life would know this already.
08-01-2010, 06:36 AM - 1 Like   #5
Class A's Avatar
No. Saving "one" JPG isn't enough to "know" this. You need at least two to be able to compare.
Note that I didn't provide a link to the article -- which many seem to find helpful -- for the breaking news, but because the author went through some length to actually illustrate the differences for the various LR JPEG quality settings.
Did you know that LR only supports 13 quality levels and just maps 0-100% to these 13 levels? I guess you didn't so the article could be useful even to those who are knowledgeable about JPEG compression in general.
08-01-2010, 07:32 PM   #6
hcc
hcc's Avatar
I do not use Ligthroom,. But both PTlens and Noiseware software recommend explicitely 90% as default:
"At 90% no difference can be seen when the image is compared with the original and viewed at 400% magnification. At 80% and below image quality deterioriates. (default = 90)." (PTLens Help file)
Food for thoughts...
08-07-2010, 05:55 PM   #7
mysticcowboy's Avatar
It's so true about JPEG quality settings and file size. If you want the best possible image for archiving, a 16 bit TIFF in Pro RGB, or at least Adobe RGB, is the way to go. The 8 bit JPEG file will never hold the information of 16 bit one. JPEGs for working files like those you send to a printer or backup online will be fine at 90%. For web display, 70% usually will equal monitor resolution.
When I used to teach Photoshop and web design classes, I had dozens of students, over dozens of classes, save their files at different settings. Nobody could consistently pick a 90% from a 100% JPEG file in a blind comparison test, with either 300 dpi prints or 100% monitor display. Forget Photoshop settings of 11 or 12.
08-07-2010, 09:06 PM   #8
QuoteOriginally posted by mysticcowboy Quote
As your student, my question would have been does a 98% jpg that has to be reopened and saved twice more (I know, poor planning) degrade to a much lesser extent than one saved at 90% three times. Do i end up with obvious differences in quality between the two final editions? thanks.
08-18-2010, 09:30 AM   #9
QuoteOriginally posted by imtheguy Quote
There will be some degradation in quality. Some people say that any degradation is too much. Some won't notice the difference. I would, but I look at a lot of images. If you don't then there's no problem. It also depends on the image. If there is a lot of very fine detail or very subtle gradients, then re-saving will be noticeable in prints. If you're only posting them online its less likely that you'd notice.
By using jpeg you have already degraded the image from what's possible.
08-18-2010, 02:32 PM   #10
Class A's Avatar
There will be some degradation in quality. ...
The question was: "While higher quality settings do not produce visible differences for the first generation JPEG, are they perhaps beneficial for 2nd, 3rd generation versions of a JPEG?". Good question which you didn't address in your response.
JPEGs allow for less latitude in post processing compared to RAW or 16-bit TIFF files, but I'd be surprised if you were able to visually distinguish prints made from high-quality JPEGs vs RAW files.
Why do you think it becomes next to impossible to distinguish the topmost quality settings for JPEGs? Because a certain amount of degradation cannot be removed, no matter how high the quality setting, or rather because at a certain point there is nothing to improve upon anymore? I don't know about the existing implementations but in theory the principle behind JPEG compression allows a 100% reconstruction of the image as long as you store enough data. Progressive levels of compression are achieved by increasingly throwing away data pertaining to the highest remaining frequencies in the image.
08-19-2010, 01:42 AM   #11
Why don't you try it yourself? I'm sure you have an image editor on your pc.
08-19-2010, 07:22 AM   #12
QuoteOriginally posted by simico Quote
Of course I have tried it but if I had a good eye for this I wouldn't be using JPG in the first place, right? I am not even proficient enough in PP to make RAW conversions look any better than the JPG the k20d spits out on its own. Thus, vote of no confidence in my ability to analyze JPG differences.
08-19-2010, 07:31 AM   #13
JohnBee's Avatar
Wow great post!!!
I love the webpage design and functions too(very intuitive).
I don't know if the image samples are coming across intact in FF but I was still able to experience the details across the difference examples(quite fun).
A funny thing about image grain is where I've been working in RAW for so long that I've grown hyper sensitive to JPG's now
Though for straight out of camera experiences, I think JPG is an excellent solution as a small, reliable and accurate medium.
Anyways, I just want to say great post once again.
Thanks!
08-19-2010, 08:02 AM   #14
That is the article I ran across a while back that first got me thinking about using less than max JPG setting, but ONLY for snaps I had no expectation of ever editing again. Thus my question about multiple saves. Guess I can take a clue from J Friedl but instead of just a 1-12 group in PE8, make my own whereby the same shot saved at setting 9,10,11 and 12 is resaved (with a tiny change) at the same setting. Maybe successive saves should go up a step? This is the question I started with.
....so much to learn to catch up with the rest of you.
compression, examples, export, increase, jpeg, lightroom, photography, photoshop, quality, settings
K-x vs K-m JPEG quality deadwolfbones Pentax DSLR Discussion 8 11-21-2009 08:47 PM
RAW + JPEG with JPEG on One Star quality laissezfaire Pentax DSLR Discussion 58 12-10-2008 02:42 PM
Jpeg compression quality Cambo Pentax DSLR Discussion 4 06-01-2008 03:19 AM
JPEG gallery quality Duncan J Murray Site Suggestions and Help 1 04-27-2008 02:38 PM
K10d JPEG quality rwa Pentax DSLR Discussion 35 11-29-2007 09:34 AM
All times are GMT -7. The time now is 02:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
