I have been using the FastStone, ufraw & Gimp combination on Windows as I would like to have the option to use the two latter on Linux too. I'm quite sure the Adobe stuff is more convenient and the price for Photoshop Elements is not bad either, so I have been tempted to get that. However, after much tinkering I've found that the following works for me (most of the time :-):
1) Import pictures (I use .DNG) in FastStone,
2) for the better ones launch Gimp from the right mouse button menu,
2.1) This brings up the image in ufraw where I use the default settings mostly, except:
2.1.1) "Color Matrix", gamma=0.34 and linearity=0.063 under "Color Management", these seem to produce similar results to k-x's Natural preset, YMMV.
2.1.2) under "White Balance",
- adjust exposure keeping an eye on the preview and the histogram (try to bring it to the middle, avoid overexposure)
- adjust WB if camera setting doesn't look good (lower K values to correct yellowish tint typical for tungsten light, higher K for bluish tint typical for shadow light outside, or pick a reasonably white/grey spot and use the eyedropper button to set based on that and adjust to suit)
- "Apply color smoothing" (have the button with the paintbrush icon 'down')
- Denoise if needed (high ISO), a rule of thumb could be: 20-40 "slight", 40-80 "moderate", 80-160 "heavy"
2.1.3) "Correct luminosity, saturation"
- Use auto black point and maybe adjust the curve for more contrast (see attachment)
3) Launch Gimp (with the OK button)
- crop and resize as needed
- sharpen with unsharp mask (try e.g. radius=2, amount=0.5, threshold=5.0 to get started, adjust amount first)
- save as JPEG (70% = "*" quality, 95% ="***" quality)
At all points I do saves as JPEG to the same directory where the DNG is for convenience and use FastStone's full screen view to see the results.
Note: by default ufraw uses the settings from last time, so look out for that.
