Originally posted by thazooo If you have a higher end monitor and printer that can display and/or print the RGB color space that's great, I do and I use the color space. Judging from the OP question, I don't think that applies. They appear to be working on an average system with a low end monitor. Suggesting using the sRGB color space should help getting the prints to match a bit closer.
When this digi 1st. started it was easy to take a shot, load it and print it. Colors matched quite well. This all occurred using the sRGB color space, yeah many years back.
Same can apply today and does for most folks using the small digicams. Load them and print.
If the original poster wants to upgrade to higher end stuff, that's cool and they will have to do the studying you suggest.
Dubious using sRGB, probably not, most print labs want sRGB files.
Yes, lots of people shoot images in sRGB and lots of labs are comfortable working with it. It is just not the only way to go, or the best.
One concern is that the OP might downgrade image files to sRGB, taking away the opportunity to work on the images in a better colour space as skills improve.
To the OP: If you are curious, you could experiment with printing images from both colour spaces. See for yourself. If you don't have problems with Adobe RGB, that's what you should use. I don't know of any modern printers that would have problems with Adobe RGB.
I started digital printing in the early 90s- before the first Epson Stylus Photo came out, and before Windows supported colour management. I began with a Fargo thermal dye sublimation printer. That was an adventure.
In my experience, getting colour right was a more complicated process than your "take a shot, load it and print It" description. If you were lucky and the gear you were using all happened to to be calibrated similarly out of the box, it's not impossible. However, it was a matter of luck rather than good technology.
I'd much rather work in a colour managed environment. You don't have to be obsessive about it, but getting the basics right avoids a lot of frustration and money wasted on bad prints. I calibrate my monitor, use manufacturers' profiles for printing, and get along just fine.
