Originally posted by procyon Do I understand correctly that you tweaked settings on your monitor (and I mean here using the buttons directly on your monitor) and then tried to get them back to normal by using calibration ?
That doesn't work, as the calibration only changes the signal that goes from the graphics card to monitor. The calibrator has no control over monitor settings. I am no expert, and I think you should consult your calibrator manual for that, but IMHO the monitor settings (again I mean the settings that you can change by physically pressing buttons on your monitor) should be set to some neutral setting that looks OK even without calibration. The calibration changes the video signal in a way that tries to compensate monitor inaccuracies, but it has limits.
Changing monitor settings very much off from normal creates a case just like when you would shoot a picture through a filter that eliminates most of lets say blue color, and then you would try to crank the blue channel up in post processing. It wont work beyond some point.
Thanks much taking the time to reply. Appreciate it.
Since I posted my original message I've had an "ah-ha" moment. I found a bit of info. in the knowledgebase of the Spyder manufacturer's website that said for the most recently updated version of the Spyder2Express calibration software, you need to set the native whitepoint of your monitor to 6500K. Since I had always used the much cooler temp of the native whitepoint, I think that's what was throwing my original calibration off. That bit of info. and a few other pieces from the knowledgebase made me understand a little bit better what exactly is going on during the calibration process. Can you tell I'm pretty ignorant when it comes to monitor calibrating?
I guess what I was trying to do is test my Spyder to see if it's actually functioning correctly. This part I'm still not sure on. At the end of the calibration process there is an image that you are allowed to toggle back and forth to see the difference before calibration and after calibration. I've never seen any differences in toggling this image. ??
Thanks again for taking the time to reply.
