Enough with Pentax dedication. I made the switch to Canon. Really good product!
Regarding flashes that is.
Got some off-camera flashes to go with my Cactus V4. It's a lot of fun. Got some good result with mixing indoor flash with outdoor lighting already. But once you get into artificial lighting there is a whole string of things to get as well: diffuser, beauty-dish, umbrellas, stands...
But luckily DIY goes a long way. Successfully used a cereal box as a snoot already.
Originally posted by CWyatt Does anyone know if there is a Pentax AF540 flash available to hire in the Wellington region?
Do you need a dedicated flash? My most dedicated one is a
Centon FG105D which supports a lot of automation, swivels and bounces, should have about the same guide number as the AF540, but it is a TTL flash so there is no automatic exposure on a post *ist Pentax DSLR.
All my other flashes are non-dedicated flashes intended for off-camera use. One of them is an auto-flash so supports a bit of automatic exposure but that's nothing like P-TTL support.
EDIT: Just in case it wasn't obvious: I'd be happy to help out with my gear if you think it would do the job.
