12-04-2009, 07:59 AM   #1
eccs19's Avatar
ISO question
I'm just curious. What's better. If you've got an object that your taking a picture of in low light, and your tripod mounted, would you be better to use a low ISO and a slow shutter speed, or a higher ISO and a faster shutter speed. I'm just wondering what way would produce less noise.
12-04-2009, 08:05 AM   #2
Wheatfield's Avatar
Try it and find out.
This way you'll know for sure.
12-04-2009, 09:20 AM   #3
YJD
YJD's Avatar
It should be low ISO with slow shutter speeds.
12-04-2009, 09:52 AM   #4
Nesster's Avatar
Yes, low ISO is lower noise. However, if the object is not stationary, you want a higher shutter speed.
12-04-2009, 12:04 PM   #5
Ash
Ash's Avatar
As above, with the caveat that you have a lot more flexibility with still-life. Anything moving, and you want to freeze that movement, will require a higher shutter speed and therefore a higher sensitivity to allow for that.
You basically have to know what the shutter speed is you're after for the particular shot and choose your aperture and sensitivity accordingly.
12-05-2009, 03:48 AM   #6
Barnster's Avatar
The higher the iso,the noisier and grainier it gets.But like ash says,if you want to freeze the movement best as possible,it will give you the ability to use a faster shutter speed for this.Experiment and eventually you'll work it out.
12-05-2009, 04:28 PM   #7
jeffkrol's Avatar
QuoteOriginally posted by eccs19 Quote
The more photons the better is what I say.
Low iso also has a larger dynamic range.
camera, iso, photography, shutter
ISO question dawsonscholz Film SLRs and Compact Film Cameras 10 05-25-2010 11:28 AM
K-x ISO 100 question VincenTC Troubleshooting and Beginner Help 2 03-24-2010 08:31 AM
ISO 100 question pakuchn Troubleshooting and Beginner Help 19 12-25-2009 06:23 AM
ISO question netuser Troubleshooting and Beginner Help 3 07-31-2009 10:36 AM
ISO improvement question? beaumont Pentax DSLR Discussion 5 06-08-2009 07:55 AM
All times are GMT -7. The time now is 08:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
