Originally posted by NaClH2O In the thread below I was bragging about how well the K10D stood up to heavy weather. Unfortunately I spoke too soon. I tried this morning to delete the memory cards I had filled on Sat and Sun and I've found out to my great dismay that my menu does not work correctly. I can scroll horizontally between categories: capture, setup, playback etc, but when I try to scroll down within a category all I get is either "MEMORY CARD FULL" if I have a full memory card, "NO MEMORY CARD IN CAMERA" if there is no card in the slot, or the initial turn on info screen if there is a non full memory card in there. I cannot access any menu functions at all. The Fn button is not working properly either, the functions display on screen but the only one I can access is White Balance, the others blank out, and I cannot scroll up or down in the white balance settings. I'm stuck in ISO 400 also. Most everything else in the camera seems to work, AF, SR, etc. I'm guessing that there is something wrong with the four way rocker switch, but I'm at a loss on what to do next other than leave the battery out for a while as see if that helps.
Anybody out there with any ideas? My niece graduates tomorrow morning and I was hoping to be able to capture the moment. I can use my DS if all else fails but is there anybody who can help?
NaCl(don't brag, the gods will get you)H2O
When you left it to dry, did you have a lens on? If so, try without a lens, the moisture can't get out if you have a sealed body.
