Originally posted by Class A This topic has already been discussed in
this thread.
You may not like the answer, which is that the correct value depends on your distance to the subject.
There is a one-to-one relationship between the distance to the subject and the magnification.
It turns out the focal length that should be entered is
Actual_Focal_Length*(1+magnification)
This is because the length of the optical "lever arm" that moves the image over the sensor due to rotations about the lens is f(1+m).
If your lens/extension tube, etc is too automatic & the camera doesn't ask for a focal length, you can fool the camera by placing a piece of aluminum foil over the electrical contacts when you mount the lens/extension tube (squish the foil between the lens and flange.)
Dave
PS not that this is going to fix all your stability problems for hand-held macros but it will help. At high magnifications, in-out & side-side motions of the camera also have large effects.
