I think you're right, it was the infinity focus that messed you up on these. Typically, many lenses allow the focus to travel a bit beyond infinity introducing a little fuzziness from that.
Once i have my tripod up, i manually focus about 1/3 of the way into the picture so i get that hyperfocal thing working. Then i turn off AF and work with that one focus setting. Also can use the AF button with half shutter focus turned off in the Custom menu.
Unless i need a faster shutter to freeze some motion, then i always use ISO 100 or 200. Using higher ISO's makes the image more sensitive to bringing up noise during pp. It could be that wave motion or wind was moving those masts and rigging, but it looked pretty calm. I think the primary culprit is the focusing.
I used cheap plastic tripods for many months because i couldn't make up my mind about a quality tripod. Unless one has those spindly little tripods, the more full size plastic tripods don't do such a bad job if you use the 2 sec or 10 sec shutter opening. I have a quality tripod now, and i would be hard pressed to tell the difference in the shots between the quality tripod shots and the plastic tripods (oh oh, incoming ...) Don't get me wrong, i love my new tripod and find it faster to set up and have more assurance its not going to dump my camera on the ground, but i took some fine images with the plastic ones too :-)
Actually the sharpest image i ever got in the last 2 years was using my new tripod on a concrete sidewalk. Its important that the feet be on something solid :-)
As to lenses, i've used my FA-50mm the most often, tried my M135 a coupla times.
You've got a great start!
