12-15-2009, 02:10 PM   #1
Nass's Avatar
astrophotography with K-7 - issues =(. Please help?
Hello,
I've never done any astrophotography before and I'm trying to do a few nice star trails. I'm failing miserably though, can anyone point me in the right direction please?
First, ideally I'd like to do several exposures and stack/merge them. I downloaded a freebie called deepskystacker but I'm having a little issue with my camera. When I set the thing to do interval shooting, every 30 seconds, with an exposure time of 30 seconds set manually, there seem to be gaps between the joined images. Is this because the camera is doing some processing in between and how would I avoid that please?
Secondly, I'd like to do this for exposures longer than 30 seconds but the in-camera limit seem to be 30 seconds. Is there any way around that?
many thanks in advance
12-15-2009, 02:17 PM   #2
You are getting gaps in the trails due to dark frame subtraction by the camera.
The only way to go beyound 30 seconds is to use the bulb mode.
If you take a 5 minute shot, the camera will take about 5 minutes to finish dark frame subtraction. I don't believe anyone has found a way to turn all that off.
12-15-2009, 03:22 PM   #3
Nass's Avatar
Thanks wildlifephotog, I've been fiddling with it all night and whilost I've turned off those default noise settings, it still has gaps - even for exposures at 20 seconds and seperated by 20 seconds. So it must be some inbuilt thing - is there no way to turn this off at all for shots below 30 seconds?
I thought that this is what custom setting 18 was supposed to do "slow shutter speed noise reduction" - turn all this sort of stuff off?
12-15-2009, 03:44 PM   #4
Nass's Avatar
This seems to be the best I can come up with. These is a quick and dirty 5 20 second exposures merged in HDR via CS3, with setting 18 turned to "off".
Has anyone had any success with this at all?
many thanks
12-15-2009, 05:56 PM   #5
From other threads on this same subject that I've read, no.
It appears the DFS is a separate function that can not be turned off.
If the camera is pausing between shots, then the DFS is automatic.
12-15-2009, 08:35 PM   #6
Wheatfield's Avatar
This seems to be something that Pentax doesn't do well. A friend of mine does wonderful star trails with whatever Canon is the flavor of the week.
12-15-2009, 09:34 PM   #7
i can disable DFS (dark frame subraction) on my K200D, i'd be very suprised if you couldnt on your K7. This is test i did quite a while back, 30 sec exposures.
12-15-2009, 09:47 PM   #8
Wheatfield's Avatar
QuoteOriginally posted by jezza323 Quote
DFS cannot be disabled on the K20 or K7. The scuttlebut that I heard when the K20 came out was that the Samsung sensor was just too noisy, so Pentax elected to not allow it to be disabled to hide how bad the sensor really is.
12-15-2009, 11:08 PM   #9
The K7 is more than capable of doing long exposures cleanly...
I had no problems with my stacked star trails....
This is 16 x 30sec exposures, now the important thing is TURN OFF slow shutter NR, this will effectively turn off DFS for exposures <30secs.
And keep the camera firing continuously.
12-16-2009, 02:46 AM   #10
Nass's Avatar
QuoteOriginally posted by C.W Tsorotes Quote
Tsotores, thanks. By "TURN OFF slow shutter NR" you mean setting 18, is that right?
What do you mean by firing continuously? The shutter option?
Thanks again
12-16-2009, 06:53 AM   #12
Nass,
If you enlarge each of the photos in this thread. You'll see there are small gaps in all of them.
These are caused by the delay during the writing to the card.
12-16-2009, 07:33 AM   #13
BTW. I just heard from a Pentax rep. All noise reduction and DFS can be disabled for 30 seconds.
12-16-2009, 10:19 AM   #14
NeverSatisfied's Avatar
QuoteOriginally posted by wildlifephotog Quote
You guys have piqued my interest but apparently my K20D only offers "Auto" or "On" for Slow Shutter Speed Noise Reduction. "On" enables it for anything longer than 0.3 seconds, while Auto makes NR "automatically activated according to the situation" - which is useless!!!
C.W. Tsorotes, I like your work-around, impressive photo! Does anyone know of a similar method for the K20D? (Or is it time to buy a K7? )
12-16-2009, 10:20 AM   #15
Nass's Avatar
hello again - I don't suppose you'd have a name for this rep or where this is written down (ie where he got this from)? If this is so then I must be doing something wrong - I still get those blasted gaps even with everything obvious turned off - so I was thinking about calling the service guys here in the UK to see if they could shed light on this, what I'm doing wrong!!
Cheers
camera, exposures, photography
Astrophotography iClick Pentax DSLR Discussion 1248 12-19-2021 05:07 PM
Astrophotography Naturenut Troubleshooting and Beginner Help 4 09-09-2010 07:27 AM
Astrophotography mithrandir Photographic Technique 1 11-26-2009 06:56 PM
K7 And Astrophotography Christopher M.W.T Pentax DSLR Discussion 49 11-25-2009 08:51 AM
Astrophotography elLuiggi Post Your Photos! 0 11-01-2007 05:43 PM
All times are GMT -7. The time now is 04:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
