Originally posted by justtakingpics If I have a 50mm f/1.7 lens and I put a bellows on it and move the bellows 50mm. Doesn't that give me 100mm lens?
No, a 50mm lens + 50mm extension tube or 50mm bellows does not give you a 100mm lens. It gives you a 50mm macro lens.
Originally posted by justtakingpics If it does does that mean it is the same a 100mm lens without bellows? I'm confused as to how the bellows makes the lens magnify more and how that differs from a lens without bellows at the same focal length.
Each lens has a "minimum focusing distance" (MFD). This is the minimum distance from the sensor plane (NOT from the front of the lens) to the object so that the object is still in focus. For most "non-macro" lenses, the MFD is roughly 10X focal length. At this distance, the size of the image on sensor is about 1/8 of the actual size of the object (1:8 magnification ratio).
So a "non-macro" lens with 100mm focal length has MFD about 1m (3 ft).
A lens (or to be exact, the optical part of it) is closest to the sensor plane at infinity focus. To focus closer, the lens has to be moved further from the sensor. You can see this by looking at a single focal (prime) lens: it is shortest at infinity focus, and longest at MFD. A macro lens has the ability to move very far from the sensor. When you add bellows or extension tubes to a "non-macro", you mimic this behavior of a macro lens. You can also add bellows or extension tubes to a macro lens to increase its magnification ratio.
Originally posted by justtakingpics Can I just keep moving the bellows out to get better magnification (where does it top out)?
In theory, yes. In practice, the bellows has limitation as how long it can be. Also, the longer the bellows, the dimmer the viewfinder becomes. And at certain magnification, the stability of the setup (camera, bellows, ....) becomes an issue.
Of course at certain length of the bellows, the object has to be
behind the front of the lens to be in focus at the sensor plane! For example, try to add 100mm bellows to a lens with FL of 28mm.
