Hello everyone,
I have a problem with my kr, after a fall the camera locked with mirror up..... and after dissasembling it, I found the problem in the mirror mechanism, the load spring lever for the diaphragms was offsite, I lined all up and everything is in order.
http://i.imgur.com/b0zZi.jpg
Now I have another problem, during disassembly I unsoldered many cables, writing on paper the order of the colors, but I forgot 4 cable.... I will not risk to solder them guessing with the lenght etc... I prefer to ask for help here.
If someone has the repair manual will solve directly my mistake, or I'll ve to ask you this favor, which is very easy, need to remove the bottom of the k-r, ie unscrew the 10 screws (8 plus 2 on the edge inside of the battery door) and just look at the color order of the 4 wires that are soldered and somewhat hidden behind the display/LCD (using a tourch/light and a bit of an eye you should see well).
From my pictures, should be (gray-red-white-brown) as they were attacked in order on the tape, but I can't risk.
If you can take a picture, will be the best
http://i.imgur.com/1uOQS.jpg http://i.imgur.com/38qcN.jpg
I don't know what favor I could give in return, but if you need any help with the disassembly and repair I have photos and drawings of the k-r....
