08-02-2013, 11:33 PM   #1
M42 Help Pls!
So my generic M42 adapter (Neewer) arrived yesterday. I'd read that attaching it to the lens first was a good idea, so I tried it on a Helios 58 44-M 4. It fitted nicely so I tried both on my K100DS - also fine. I removed it and tried again, no problem. After a short shoot with the combo I removed the lens. Of course at this point I was elated at how simple the whole process appears, so emboldened I did the same with my SMC TAKUMAR 135 F3.5. My euphoria at the brilliant results with the TAK turned immediately to horror when I realised that the lens & adapter are both turning in the mount, but not releasing from the camera - Panic I have not used the lens before but I note that the Auto ring below the Aperture ring is stuck in the Auto position. The adapter seems firmly screwed into the lens and both turn in the camera mount.
I'm really hoping someone may be able to help before I consider removing the mount from the camera or going to the camera shop.
HELP pretty please!
08-03-2013, 12:33 AM   #2
altopiet's Avatar
Are you trying to get the lens off by using the lens release button?
08-03-2013, 12:44 AM   #3
QuoteOriginally posted by altopiet Quote
Yes I've engaged the lens release. It seems to make no difference now, the assembly of lens & adapter move anti clockwise and then clockwise with or without the lens release button pressed or not.
08-03-2013, 01:05 AM   #4
altopiet's Avatar
So, if I understand you correctly, the lens is tightly screwed into the adaptor, no movement there? The front of the adapter should be flush with the outside of the camera mount if engaged correctly when you put on the lens the first time... is it still flush? If so, then it is supposed to be locked into place into the mount and you should either be able to use the lens release button to remove the lens with the adapter attached, or without using the lens release button, by simply unscrewing the M42 mount. Even if screwed on tightly, you should be able to unscrew it although with a little effort. The fact that everything is turning around, seems as if the adapter was not correctly engaged the first time, not locking into place properly. Try either pushing or pulling while turning the lens, anti clockwise, forcing the adapter to lock onto something. If you can turn the lens out of the adapter, you should be able to see the mounts properly and identify the problem.
08-03-2013, 01:09 AM   #5
altopiet's Avatar
Can you take a pic with your mobile or something and post it?
08-03-2013, 01:14 AM   #6
I want to correct this. It's not possible to remove the lens adaptor using the lens release button. One can only remove the lens adaptor after first removing the m42-lens.
08-03-2013, 01:19 AM   #7
altopiet's Avatar
QuoteOriginally posted by Phii Mii Quote
Sorry sir, I do it all the time, you just have to remove the screw and lock spring from the adapter, and I think that is what the OP might have done
08-03-2013, 01:24 AM   #8
altopiet's Avatar
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/117168-attachi...ntly-lens.html
08-03-2013, 01:32 AM   #9
- Right
- I think the adapter was flush with the camera mount, certainly enough to get well focused photos up to & including infinity. It is no longer flush: the lens & adapter assembly can rotate anti clockwise & back, with or without depressing the lens release. Also there is now play between the assembly & mount, not much but it is no longer flush.
- Possibly
- I have been trying this but am concerned about how much effort to exert. I can't afford to kill the camera or lens
- Because the lens/adapter move & aren't flush I'm having difficulties getting the lens off the adapter - Just not sure how much force I can use.
I'll try and get some photos.
Thanks fot the hand holding!
08-03-2013, 01:40 AM   #10
altopiet's Avatar
No problem, and although I can not guarantee it, the camera mount is quite strong, I had my various strong arm fights to get M42 adapted lenses from the mount. If you get the adapter to grip while pulling the lens and turning anti clock wise, just increase the pressure gradually, until the adapter releases from the screw mount of the lens, no sudden forceful yanking or pulling, gradual increase of pressure is the key, almost like unscrewing that jam bottle that the missus usually bring to you to open
08-03-2013, 01:45 AM   #11
altopiet's Avatar
O, and before doing it, it does help to say a little prayer
08-03-2013, 01:49 AM   #12
Ahaa, that could very well be the case. I thought he used the adaptor as it was ment to be used I have about ten m42-takumars and never had any problems when I use them. But I only change lenses like in the old Spotmatic time
Anyway, good luck GBNeil. I hope you'll be able to remove the lens and adaptor.
08-03-2013, 01:52 AM   #13
altopiet's Avatar
QuoteOriginally posted by GBNeil Quote
Can you link us to an image of the adapter?
08-03-2013, 01:52 AM   #14
Na Horuk's Avatar
Btw, I think people often have problems with off-brand m42 adapters, so feel free to search this forum for threads on it and maybe you will find a solution. Its most important to stay calm, because panic can do more damage than a faulty adapter
08-03-2013, 01:59 AM   #15
altopiet's Avatar
+1 on that!
adapter, auto, camera, lens, m42, mount, pentax help
Help pls - M Lens beginners question GBNeil Troubleshooting and Beginner Help 12 06-11-2013 07:04 AM
Pentax + M4/3 users pls help!!!! suoersta Canon, Nikon, Sony, and Other Camera Brands 54 06-07-2012 09:38 AM
Pentax K5 custom settings HELP PLS el baroda Pentax K-5 & K-5 II 3 05-28-2012 02:14 AM
Pentax 645 film loading help pls! Ches Pentax Medium Format 6 09-26-2011 01:30 PM
Urgent help pls bollicina31 Pentax SLR Lens Discussion 6 10-06-2009 09:07 AM
All times are GMT -7. The time now is 06:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
