Originally posted by Scott_the_Artist None of my lenses have oil on their aperture blades, but why is this a big deal? What problems does it cause?
Note that when attached to a camera body the aperture stays open.
When you hit the shutter release button, the aperture closes down to whaterver the aperture setting is, then the shutter opens, then closes, then the aperture opens up again. All happens in a split of a second. (Unless the lens is a "preset" lens that needs to be
manually closed down before shutter release).
So the aperture blades have to be "snappy." Otherwise the aperture won't close completely to the aperture setting. It "kind-of" closes and then opens. The result will be an over-exposed photo.
Oil (mainly from the grease deteriorating) can get in between the aperture blades, making them "stick" together. Over-exposed photos from a particular lens is a sign of oil contamination.
The only way to fix this problem is to completely disassemble the lens, then wash the aperture blade with solvent (I use naptha). I currently have a lens waiting to be assembled back, and another one waiting for the naptha bath.
