Quote: Ideally, I want to set up the camera on a tri-pod on a jump/ section of track, hike up, and ride down with a burst of photos taken when I come into view (focus)...
The best solution to that would be an universal wired remote (cheap from ebay) and a buddy holding that remote
Quote: @Flyer - I have a MF lens so that shouldn't be a problem, I'm a bit confused as to how it is set up on the K10D though if you say it isn't an option..
It's real easy to do - just put camera on AF and the camera will only take pictures when the center is in focus (assuming you are not using AF button on the back of the camera as the only autofocus button).
While it's easy, I don't know how viable this solution is since you have to be perfectly in focus every time you ride through the frame. Also, it will start firing only when you reach the center of the frame.
