Originally posted by Confused Hi Andreas
Ok, without spending an absolute fortune, which flashgun would you recommend for use in conjunction with my K10D that doesn't suffer from lousy build quality, but also pivots & swivels without underexposing slightly like the AF540FGZ apparently does ?
There has surely got to be SOMETHING on the market which has all these bases covered ?
I really thought this decision was going to be a damned-sight easier than it currently appears.....aaargh !!!
Best regards
Richard
Confused, this is sort of freaky. I remember reading your posts through google search as I was researching on which camera system to purchase. I was set on Canon and after much research including your posts I ended up purchasing the K10D and the Tamron 18-250. I also ended up purchasing the Sigma 10-20 and guess what's in the mail now....the Pentax 540.
I wanted a rotating and swiveling head with P-TTL, and later learned the usefulness of HSS and ended up really wanting that as well. The only flashes that fit the bill was the Sigma EF-530 DG (AFAIK not shipping yet), the top of the line Promaster (7500EDF, not yet available in US),Metz 58AF (really liked this one, not easily available in US and a bit more expensive than the Pentax 540) and Pentax 540.
I needed the flash immediately so I went ahead and ordered the Pentax 540. There are lots of factors and not so commonly understood features that have to be known prior to purchasing a flash. Do your research and you may find out that there is no ideal solution and the closer it gets to the ideal more it'll cost you.
I can tell you in a few days what this underexposure problem is all about, but to me it sounds more like what I've heard of with the K10D. K10D is not a P&S and takes some time to tune it to get the proper exposure with the various lenses and I think that's the issue with the 540 as well. It's not going to do all the work for you in all situations and I don't expect it to either.
