After many months of wavering, I finally purchased a Katzeye focusing screen for my K10D. Here are a few of my notes and observations:
What I Bought
K10D focus screen with:
- Split image
- Microprism collar
- Ground glass donut
- No OptiBright
- No grid or autofocus lines
Ordering
The item was ordered with standard shipping on December 10 and received in the mail on December 13. I was totally surprised to get it so soon.
What Was In the Box- A special tool for handling the screen
- A padded plastic jewel case containing the new screen
Installation
The installation was pretty straightforward. The confirmation e-mail included a link to step-by-step instructions specific to the K10D. The instructions were pretty good, though the photos were not particularly clear. Fortunately, the process on the K10D is fairly simple. The whole operation required less than 2 minutes start to finish.
Brightness
As noted above, I opted against spending the additional $49 for the OptiBright treatment. As such:
- Viewfinder brightness is directly related to lens aperture
- With slower lenses or narrow apertures on manual lenses, the viewfinder is distinctly dim...much more so than with the stock screen
- With fast, auto-aperture lenses the viewfinder image is superior in brightness and contrast to the stock screen
- Screen brightness will vary when zooming with variable aperture zoom lenses
- The split image does indeed resist black-out down to f/8 or smaller
Depth of Field
True to the advertised claim, the Katzeye screen gives a much truer representation of DOF at all apertures than the stock screen. I was very impressed.
Auto Focus
Since the auto-focus mechanism is independent of the focus screen, it was no surprise that AF functioned as expected. What was interesting was to see just how accurate the AF is and to see it snap in on the microprism/split image. With all three of my AF lenses, the split image was always on the mark at all subject distances.
Manual Focus
Here lies the reason for the purchase. In short:
- The manual focus experience is immensely improved...What a pleasure!
- Both the microprism and the split image are very effective
- The wide ground glass donut proved to be very useful for evaluating DOF and determining focus for situations where the prisms are ineffective.
- Subjects snap in and out of focus with much the same ease as a good 35mm SLR
- Focus was very accurate and more precise than the camera's focus confirm
A few cautions:
- I did not test focus with bellows, though my expectation would be that the focus aids will be essentially useless (as they are with my film camera)
- I also did not test focus with moving subjects such as motorsports or birds-in-flight, though I also believe that the focus aids will have little value there as well
Metering With "A" Mount Lenses- Spot metering is not accurate for lenses having a maximum aperture narrower than f/2
- Center-weighted and evaluative metering work as expected for all lenses with maximum aperture of f/5.6 or wider. Apparently the split-image and microprism retain a false brightness at smaller apertures that skews the meter.
- Gray-card series in all modes within the limits noted above produced accurate and predictable meter readings
Edit: Added Flash Section Below 23 Dec 2008 P-TTL Flash
According to the K10D owner's manual, P-TTL flash is supported for DA, D FA, FA, F, and A series lenses. I was able to run simple exposure series using my DA 18-55, FA 35, and A 50 and the built-in pop-up flash to confirm that correct flash exposure was attained at all apertures.
Stop-down Metering With "Non-A" Mount Lenses
As many are aware, stop-down metering may be erratic with the stock screen on the K10D. A few quick tests with my manual lenses indicate that the Katzeye screen may compound an already bothersome issue. Based on gray card series with a few of my manual lenses:
- Underexposure at wider apertures is lessened somewhat with the Katzeye screen to the extent that metering is essentially accurate for some lenses in the range of f/8 and wider. Other lenses showed no improvement at wider f/stops.
- Unfortunately, the "false" brightness of the split image and microprism regions results in underexposure at f/11 (about 0.5 stop) that worsens to 1.5 stops or greater at f/16-f/22. With one of my lenses, the meter reads the same for f/11 through f/32. Not good.
I will have a chance to characterize this issue more thoroughly later this month when I have access to a second K10D with the stock screen for comparison exposures. This issue is not addressed on the Katzeye Web site and I intend to bring it to Rachel Katz's attention once I have some data.
Quirks- The center AF indicator point is displaced to the side by the split image prism
- There is a circular line at the outside border of the ground glass donut. This line has a purpose on the Nikon screen (K3) that Katzeye machines down for the K10D. I was a little peeved at the extra screen content until I realized that it is useful for adjusting the eyepiece diopter.
Conclusions:- Great performance for manual focus using relatively fast A-mount lenses
- Dim viewfinder for lenses such as the 18-55 kit
- Severely degraded meter performance for stop-down metering at narrower apertures
I will post additional observations as I see them.
(Upset about the stop-down metering issues...)
Reason: Added section for flash exposure
