Received the MK-RC7.
Seemed finicky at first - would get stuck on half-press green mode and not respond without having to remove batteries and reinsert.
They seem to be working good now. Half-press works (I got the "Canon" version for the cord, but they said it was compatible with Nikon as well) and allows sync at 1/180 perfectly maybe 3/4ths of the time. The rest of the time there's a tiny sliver at the bottom. Without a half press, I get a dark band pretty often at 1/180, but 1/160 appears to work 90% of the time.
Pulling these numbers mostly out of my ass, have not done much range testing. Fired it on one end of my house through a couple walls next to my wifi router and next to one of my wifi clients successfully. Flash wake-up does not work on my sigma EF-530 though
and of the maybe 50 times I've fired it, I've had 3 or so missfires, of which I've heard the rf-602's are better at.
I was under the impression that the Rx hotshoe would not have a stop at the end, letting the flash slide too far forward, but this is not the case.
So far I'm pretty satisfied and will probably be ordering 1 or 2 (depending on how I like the YN-560 optical slave) extra Rx over the RF-502 for dual battery support, and the half-press recognition.
