There is also the ability to stack the filters. So you could buy 2, say a 2 and 4, stack then essentially creating a third filter of a 6, or get a 4 and an 8 to also provide a 12. In this way you will have the ability to somewhat adjust the amount of filtering achieved to some degree.
Singh-Ray's Vari-ND is an adjustable filter, where you can "dial in" the amount of filtering you want. Along the same line of thinking, I understand you can make your own variable ND filter by taking two polarizing filters and stack them. Then by rotating one over the other, you create the ability to "dial in" the amount of filtering. I have also read that for this stacking of two polarizing filters you can use two linear polarizers rather than 2 of the more expensive circular polarizing filters (CPLs).
