EDIT: 08DEC2012 - I have just added this review of the tripod. This review can also be seen in the accessories review section or the tripod review section of this forum.
Benro MeFoto A1350Q1
First off there are two versions of the MeFoto tripod a tiny
travel version and a larger
transfunctional one. A smaller one that is tiny in size and can only withstand 7-8 lbs and cannot be transformed into a monopod. Then there is a slightly bigger one yet small that can withstand 17-18 lbs and be transformed into a monopod.
I bought the A135Q1 which is the bigger one. It also comes in 5 colors, I bought the blue one.
Well for the first time with the tripod today, I extended all of it's leg out and placed my camera on top and did the wiggle wiggle around, it is solid in place and no wobbles. It is very strong and sturdy in place and can withstand between 17 and 18 lbs. I even gave it a little push down with my hands against my chest and this thing is a keeper. My old tripod which is a Amazon $40 dollar one that has less leg sections can't even phase this in quality. The only time this Benro has a wobbly piece into play is when you unscrew the smallest section to pull the leg down, other than that when you screw it back in, it stays in place and is rock steady. This tripod is heavier than it looks but by no means is it too heavy. It's got quite a feel to it, it feels like it has a lot of strength based on it's weight. Once again, it is VERY SOLID for it's size and the amount of leg sections it has. You definitely can tell this tripod is worth in the hundreds pricing. The tripod head's adjustment rings are made of thick high quality rubber and so are the twisties for the leg section. My old Amazon $40 tripod looks like a heavy duty tripod, yet feels like a toy. Yet this Benro Mefoto Transfunctional tripod, looks like a toy, does not feel like one at all. Love it so far, will update more on this post in the future if necessary and needed.
For those who don't know about Benro, it is a chinese brand tripod maker that literally makes Gitzo tripods at fractions of the price. Doesn't mean that it's all out knock-off cheap brand. This brand makes really good tripods, don't let the Made in China fool you.
Advantages:
Extremely compact design for easy around carry. It folds out to about/around 5 feet, 7 inches.
A lot more solid and durable than it looks.
Aluminum designed twist-to-release legs design is more sturdier than plastic clip-to-release designs.
Comes with a decent ball-head that has ability to pan and adjust panning speed.
Ball head has 4 notches to adjust position of head and to adjust friction of rotation needed to move around the head.
Comes with high quality bag for storage. Bag even has a adjustable strap.
Can be turn into a monopod within a few minutes.
Arca Swiss compatible!
Disadvantages:
Heavier than it looks, it's possibly heavy because of the solidity and high build quality.
Twist-to-release leg sections can take awhile to get used to.
May take a little longer to put back into it's folded form than clip-to-release.
Four leg sections rather than three may take up more time to get set-up.
Spirit-bubble(Leveler) is a little small and hard to see.
Walkthrough of my new tripod below.
Other big online stores are selling this tripod for 229 USD, however with my student discount, I only bought it for 125 dollars from a website that sponsors my school.
This tripod is tiny! Just look at the bag and the Tripod (folded) to my DA* 50-135 f2.8, the lens is about 3/5th the size with it's hood attached.
Let's look at the head, it has 4 nozzles to adjust all kinds of stuff.
The Arca Swiss style quick release plate.
It can be taken apart and turned into a monopod!
To quickly and simply extend almost all the length of one tripod leg, simply grab as much of it as you can and twist.
Maximum height is about 5'7, I am 5'8 so this is perfect.
