Two new batteries tested. Even though these were Chinese made batteries, they claim to use Japanese made cells. They also shipped from California instead of China.
You will notice that these are rated at 2000mAh or about 23% greater capacity than the OEM Pentax batteries. At about $9 per battery that should be a bargain. These batteries weigh about the same as the Pentax batteries at approximately 78 grams each. Let's get to testing.
Using the CBA II I ran both batteries through three cycles to make sure there wasn't an issue with the batteries themselves. These cycles were done at a 1C discharge rate to ensure that there were no issues with the individual batteries.
These Chinese batteries were tested with the following parameters:
Battery Type > LiIon
Battery Capacity > 2.0
Battery Voltage > 7.4
Battery Cells > 2
Test Type>Discharge
Cutoff Voltage > 6.0
Discharge Current > 0.5
The Pentax battery was not retested for this round.
I choose a discharge current of .5 Amps as this is what I suspect the average drain from a mix of screw drive auto focus use and internal flash use might average out to and to keep in line with best practice when I tested AA and AAA batteries in the past.
I performed each discharge test about 10 minutes after pulling the batteries off the Pentax D-BC50 charger. The 2000mAh Chinese batteries were consistent and had a power curve very similar to the 1800mAh batteries. The voltage sustainable under load was just a bit less than that of the Pentax OEM battery but not enough to affect camera operation. The consistent readings does indicate that there is some quality control built into the manufacture of these batteries. They are not totally junk. The real truth was revealed when I got the capacity results. Again let me remind everyone that stated capacities are usually measured as a percentage of the total rated output. That measurement is usually .2C or 20% of the rated capacity, so in order to see a reading of 2000 mAh I would need to test them at .4 mAh not the .5 that I did. Because of this we should expect the numbers to be lower. In nearly all the tests I got just over 1400mAh as the actual capacity from these batteries. By comparison the OEM Pentax, rated 23% lower, actually output 1550 mAh at the same current draw or about 6% more power.
Are these Chinese battery worth the cost? Well these two batteries cost me about $18.00 shipped from California. The Pentax battery is currently available from B&H for 46.95 + shipping. Another disappointing purchase if you are expecting these batteries to last longer than the Pentax.
Bottom line: Chinese 2000mAh battery
6% less capacity and
1/5 the cost. Another toss up, you decide.
I also got a back-up charger that I will report on some time in the future.
The attached PDF lists all the battery tests to date. I will update it with my findings on some 1720mAh batteries that have still not arrived. These will most likely be the last batteries I will purchase. If anyone wants their batteries tested for capacity we might be able to figure something out.
