Hi, I'm the guy Ratmagiclady knows to ask about this, and I'm now online.
I'm actually not a Pentax shooter, but I figure my experiences dabbling with solar battery charging cross company lines. It's a matter that concerns us all.
Getting a solar setup to charge DSLR batteries is actually quite simple. All you need is a charger for your camera battery with a 12v car plug and a panel that both offers a female cigarette socket adapter AND will punch out enough juice to get the charger going. The later is a concern, but not a huge one. More on that later.
If you just want to one-stop shop, Sundance Solar is bundling folding panels and Pentax chargers:
Solar Charger for Pentax with SunLinq 6.5 Watt Foldable Solar Panel Solar Charger for Pentax with Sunlinq 12 Watt Foldable Solar Panel
I own the 12w Sunlinq and I definitely recommend it over the 6w model. While I assume Zambia is going to be getting some pretty healthy doses of sun in late summer, additional output potential is always a plus with small-scale solar gear and the double fold 12w model isn't meaningfully heavier than the 6w. In either case, there's newstand magazines that are heavier, so they're not much burden to throw in your pack. If your budget can afford one per person, that's handy so if necessary you can charge more than one battery at once. Folding panels are pretty much only going to power/charge one thing at a time even under the best of circumstances and, under less favorable sun conditions, it's possible to wire a pair in together with a Y-cable so you can try to eke out some juice even when it's a bit cloudy.
The charger on offer looks identical the ones I have for my (Nikon and Casio) camera batteries, a couple of which I bought under the "Impact" brand, but one generic off eBay. They're nice units that are 110/220v autoswitching with folding wall plugs in addition to the detachable 12v car plug. I pretty much just use them full time for both solar and wall charging and put my OEM chargers away.
You probably could get a slightly better deal if you carefully shopped for the panel and charger separately, but I haven't been shopping them lately so I don't know what the going prices on the panels are. I know I paid less, but that was months ago.
Now, quick word about sufficient power output.
If you get yourself one of the aforementioned panels or other branded equivalent, your only concern is getting enough sun and you'll have the necessary power to charge up. The only case of a solar charger with a cigarette socket adapter being unable to keep up that I've run into is the Solio, which is a great little device, but it simply isn't built to provide the juice that DSLR batteries need.
During last summer, once I had all the hardware figured out, I was charging my DSLR batteries in the sun full time and not plugging into the wall at all. I live in the Pacific Northwest too, which isn't renown for the strongest solar intensity. Zambia's going to have much more efficient solar intensity, but I'd still keep a couple spare batteries just to ensure you got power.
