To mark success/narrow escape on my Pentax ist DS dslr, though I'm sure it's peanuts to you young techno guys.
Here's the boring story....(it's about SDHC cards and firmware updates zzzzz........)
Saturday, and thought to go print out a photo at Jessops photo shop instant self-print Kodak machine. Very convenient and cheap enough, 19 pence for a 6x4. Then saw Gb-sizes SD cards there are now quite cheap. Maybe I could bring lots of photos on it and get over 200 photos at 5 pence each for overnight printing, from years of digital shooting. Went down to Staples stationery warehouse...they had even cheaper ones, and picked up a Lexar 4Gb for GB 8 pounds. Thought yaaay, now instead of the measly 512Mb SD card, I now have a much improved 4Gb SDHC memory for a small cost.
Wrong.
Put the card in....'memory card error'. Immediately thought....probably does not support SD 'HC' high capacity cards. Online at Pentax Forums I found this is true, and as hoped, fixable by firmware update. Mine was version 1.0, about 5-6 versions behind the most current, 2.02. Did 1 hour or so precautionary reading, as I know from mp3 player experience that a botched firware update (e.g. due to failed battery/power halfway through) can really damage the camera. Recharged my camera batteries and went for it. Yaay success! Now I have 8x more memory on the one card.
______________________________
Download the ist DS firmware 2.02 update from here >>
Software Downloads : Support & Service : PENTAX
What I did (as per the read-me file that comes with the updater, added to slightly by me to make it more complete for novices, like me).
PENTAX istDS Firmware Updating to Version 2.02
* Firmware is the software that runs inside digital cameras.
Updatable models
istDS digital SLR cameras running Firmware Ver. 1.00/1.01/1.02/2.00/2.01
How to check version
At this point, there should
NOT be any kind of .bin or updater file on your SD card
that's in your camera. By this, I mean an
SD card that already has been working
in your camera.
Turn the power on while pressing the MENU button.
The Firmware version is displayed for about 5 seconds at the center
of the LCD monitor.
* * * * * * * * * * * * * * * * [Caution] * * * * * * * * * * * * * * * * *
You are recommended to use the AC adapter (optional) when updating
Firmware.
If you are using CR-V3 lithium batteries or AA batteries, make sure that
batteries are fresh.
If AA Ni-MH rechargeable battery is use, be sure to use fully charged battery (this is what I used, 4 fully charged 2700mAh Uniross rechargeable Ni-MH).
If the camera turns off during updating due to lack of battery power, the
camera will become inoperable. If this happens, a charge will be made for
repairs even if within the warranty period.
UPDATING PROCEDURE
1a. Before you update the firmware, it may be an idea to note down any custom settings you have set (at your camera, press Menu, scroll right to 'Custom Settings'). It will save you time later setting up the camera after the update (step 11b).
1b. Connect an
SD memory card (one that is already proven to work in your camera) with at least 8 MB of available memory space to your PC.
The downloaded file updater from Pentax is self-extracting. Double click on the downloaded ds_e202w.exe file.
The following files are extracted.
readme.txt : this document
fwdc131b.bin : Firmware
Copy the above Firmware file [fwdc131b.bin] to the root directory in
the SD card ( i.e. immediately in the SD card and not in any folder in there).
If your computer does not have a card slot, you can copy the firmware
update file by inserting the SD card into your camera and then connecting
the camera directly to your computer.
2. If the camera power is on, turn it off.
3. Insert the update SD card (prepared in step 1) into the camera.
4.
Connect the AC adapter to the camera if you have one, to use AC power.
If you are using a rechargeable battery, make sure that it is fully
charged (this is what I used, 4 fully charged 2700mAh Uniross rechargeable Ni-MH)., and if you are using batteries that are not rechargeable,
make sure that they are fresh batteries.
5. Turn the camera power on while pressing the MENU button.
6. "NOW LOADING" appears in the LCD monitor, and will change to the
"PROGRAM UPDATE". At the bottom of the LCD monitor,
CURRENT VERSION 1.00/1.01/1.02/2.00/2.01
UPDATE VERSION 2.02
will be displayed.
7. Press the four-way controller to select "YES" and press the "OK" button.
8. "UPDATING" appears on the LCD monitor and updating starts.
Please do not under any circumstances switch off the power before the
update is completed.
It will take
approximately 90 seconds to complete update.
9. When update is completed, the "COMPLETE" will be displayed at the left
bottom of the LCD monitor, then turn the camera off.
10. Remove the update SD card from the camera.
11a. To check the Firmware version in your camera, turn the camera on while
Check that the version displayed in the LCD monitor is 2.02.
The camera automatically starts up after about 5 seconds.
11b. Now, or at any time after is the time to set the time, calendar etc and any custom settings that you use (see 1a above).
(Caution)
When updating is finished, the update SD card still contains the
Firmware file.
If you want to use this card to take pictures, delete the Firmware updater .bin file
first.
12. If the reason you have updated is to enable your camera
to use a high capacity SDHC card, put your SDHC card into your camera. It should now work.
Reason: clarity
