09-28-2010, 05:58 PM   #1
jpzk's Avatar
SD card slot on the K5
Remember how people were complaining about how difficult it has been to get the SD card out of the K7 slot?
I was wondering if that is still the case with the K5.
Little, tiny, maybe irrelevant detail but, hey! why not ask?
JP
09-28-2010, 06:18 PM   #2
kp0c's Avatar
Someone that went to Photokina could maybe answer that...!?
09-28-2010, 06:25 PM   #3
Arpe's Avatar
Don't actually have a problem with my K-7 now, it's loosened just a tad and that is all that was needed.
09-28-2010, 07:04 PM   #4
aleonx3's Avatar
QuoteOriginally posted by Arpe Quote
Compare to my K10D, I felt the SD card door was awkward to say the least at the beginning. Somehow, I get used to it now and in fact I feel more protection from moisture and sand with the rubber cover.
09-28-2010, 08:13 PM   #5
The trick to the K-7 card slot is to press the card in then get your finger out of the way to let the card pop up. The SD card comes out easily this way.
09-28-2010, 08:35 PM   #6
twitch's Avatar
Apparantly the SD cards were very very difficult to get out of all but one of the K-5's at the show, seems the card door wouldn't open. Looks like super glue is the new weather sealing technique being used by Pentax
09-28-2010, 10:09 PM   #7
QuoteOriginally posted by Rico Quote
The first time I tried that, I launched the card across the room. That spring is pretty strong.
09-29-2010, 02:45 AM   #8
Its a relatively easy issue to fix for a redesigned body.
Pentax has shown a lot of attention to user feedback, and I can see they fixed many (not all ) of the K-7's shortcomings in the K-5. Just need to reconfirm with an actual body.
09-29-2010, 10:46 AM   #9
jpzk's Avatar
Believe me, I do take care of letting the card "slide out" after pushing on it.
But, compared to that of the K10D and K20D, I found it a bit annoying ... nothing major!
I just like to know from others what they think.
We will soon see.
JP
09-29-2010, 11:17 AM   #10
It's not major but it is a constant annoyance: every time you pull the card you have to futz with it. Moving the slot a hair towards the rear of the body would probably fix it. Little ergonomic things like this mean a lot in day to day use. They should totally fix it.
09-30-2010, 12:51 AM   #11
blende8's Avatar
I agree, this is a constant annoyance!
I checked the K5 and it's the same. Very difficult to remove the card.
The "trick" to let it pop out did not work.
It is incomprehensible to me, how they could leave it this way.
Very big minus.
The engineer who is guilty of this in the K7 is incapable!
But also those are to be blamed who allowed it again in the K5.
09-30-2010, 01:24 AM   #12
I have always wondered about the reports of tight SD cards.
My K200D came new with 2 store supplied 2GB "Silicon Power" cards and they are as smooth as silk to get in and out.
Recently I bought a generic 4GB SDHC card and it is tighter than a ferret up a drainpipe.
Perhaps Pentax build to the iso standard sizing for SD and SDHC cards but many card manufacturers tolerances are sloppy big ??.
Are we knocking Pentax for better engineering than other brands....??
09-30-2010, 01:28 AM   #13
Nass's Avatar
It's a little tight, but in the global scale of things, I'm not losing sleep about it. Open the cover, push it down to spring it and it's in my hands within 3 seconds.
I suppose life would be better if it was 2, but hey
09-30-2010, 02:10 AM   #14
Cards are plastic and dimensions are not rigidly controlled. Some are better than others. If card is sticky, use a fine file or fine sandpaper on the top and bottom edges to loosen it up a little.
09-30-2010, 02:44 AM   #15
blende8's Avatar
The card isn't too thick.
It is held back by something.
Compare the card slot with a K10 or K20.
Well, we cannot do anything anyway.
Have to live with it another generation.
camera, card, dslr, k-5, k-5 ii, k-5 iis, k5, pentax k-5, sd, sd card slot, slot
K7 SD-slot Daan Pentax DSLR Discussion 27 10-03-2010 06:21 PM
k20d sd card slot problem hitechrr Pentax DSLR Discussion 9 05-02-2010 05:18 PM
tight K-7 memory card slot, SOLVED !!! Pentaxor Pentax DSLR Discussion 3 09-28-2009 10:41 PM
Is the SD card slot sealed? (K200D) vk4akp Troubleshooting and Beginner Help 4 05-04-2009 06:22 PM
Realignment of K10D SD card slot without sending it back to Pentax? Narcoleptic Pentax DSLR Discussion 4 09-15-2007 11:34 AM
All times are GMT -7. The time now is 08:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
