10-12-2010, 05:32 PM   #1
PinarelloOnly's Avatar
K-7 and the opinions of high ISO shooting.
While waiting for the k5 to come out like the rest of us,
I did some soul searching and while I never gave the k7
a thought I started to read the pro reviews and past mag
articles from the library recently. Turns out from what I seen
and read that the k7 has put out some very good results
up against cameras like the D300s, 50D and even the 7D at
ISO 1600.
So why all the negitivity on here about the k7 in relation to
high ISO shooting? To me, it looks more and more like a bargain
at it's current price.
10-12-2010, 05:47 PM   #2
In my opinion, people often like to point out negatives, as superfluous as they may be, in anything.
The K-7 definitely does have noise at high ISOs (more than many Nikon or Canon cameras), but in my experience the noise in Canon and Nikon cameras is still there, it's just smudged out. Thus, the images aren't really sharp. The K-7 does NR as well, but not to the extent that other cameras do. I like the noise structure of the K-7, very much like film in my opinion.
Any and all flaws are visible at 100%, by the way. Nobody ever looks at 35mm slides blown up to 11x14" from a few inches away.
10-12-2010, 05:53 PM   #3
yeatzee's Avatar
The K-7's high ISO "issue" or "problem" is blown out of proportion and taken with way to much credability IMO. I don't understand the frenzy this forums members generate in regards to the k-7's "flaws." Personally, I think it is an absolutely fantastic camera as does anyone I've let use it.
My nikon buddy was just praising the K-7 because of how fantastic a camera it is... and for the price he called it "ridiculous."
really, for the price you cannot get anything better IMO
10-12-2010, 06:03 PM   #4
Lowell Goudge's Avatar
QuoteOriginally posted by brofkand Quote
I have never complained about the k7 and high iso
Here is a 100% crop at 1600 ISO and 1/40 th with a 500mm lens.
IMO the IQ is quite good and so is the SR
10-12-2010, 06:12 PM   #5
The thing about the K-7 is that, on paper, it doesn't seem like much of an upgrade. When looking simply at noise grain, the K-7 really isn't better than my K10D, and is allegedly worse than the K20D.
The thing is, though, that the K-7's grain distribution is very, very evenl and takes well to noise reduction. Furthermore, the K-7 leaves very little color cast when shooting high ISO. With the K10D I find ISO 1600 usable for abstracts, but hesitate to use ISO 800 for color portraits due to uneven gradation of the skin tones which the human eye tends to notice. The K-7, however, I won't hesitate to use up to ISO1250.
I've been without my K-7 for a couple months as I broke the focusing screen assembly and took my time sending it in (just got the invoice from C.R.I.S. today for $265). I wasn't in a huge rush to get it fixed since the K10D was handling my limited shooting needs, but going back to the K10D has definitely made me appreciate how much better the K-7 is. Nearly everything is a huge upgrade: the af is faster, the mirror blackout is nearly instantaneous in comparison, it has better DR despite DXO's test saying otherwise, the high ISO is better, the metering is better, P-TTL is better, and the white balance is worlds apart. The only thing that I feel the K10D handles better is white balance under daylight at base ISO.
I look at my K-7 shots at times and think, "I thought this camera was bad at high iso?" All shots are default LR conversions with no adjustments done in post.
50mm @ f/1.4, 1/30s ISO 1600
50mm @ f/1.4, 1/60s, ISO 1250
50mm @ f/1.4, 1/8s (handheld), ISO1250
30mm @ f1/1.4, 1/60s, ISO 1250
10-12-2010, 06:19 PM   #6
The K-7 is competitive at High-ISO with most of the Nikons and Canons in its class if you shoot RAW.
The High-ISO performance starts lagging at ISO 3200 and above.
I think the main problem is the unimpressive JPEG output straight from the camera at High-ISO.
Lets face it, a lot of people will form their first and possibly only impression of the camera from JPEG output. I hope Pentax has fixed this on its newer model.
10-12-2010, 07:06 PM   #7
QuoteOriginally posted by kittykat46 Quote
I think this is exactly it. They tend to meter a little dark (good for raw, not so good for JPEG) and apply conservative noise reduction. The K7 is really a RAW camera with an OK jpeg engine built into it. If you don't shoot raw with the K7 you really aren't going to see the best that it's sensor has to offer... I have the exact same experience with the K20D.
I think one of the issues is that these cameras retain so much shadow detail that works wonders in post... but you never see it if the image is immediately compressed.
10-12-2010, 08:56 PM   #8
LeeRunge's Avatar
The k7 can work up to 3200 in RAW with good pp techniques. It involves more work than the Canon's and Nikons for the same result. The 7d I have head to head pretty much takes a JPEG at 3200/6400 that is usable without any pp vs having to use topaz denoise/lightroom to work out the noise on the k7. At 1600 or below I wouldn't worry about it.
The worst situation I had was a Tahitian fire dance that the K7 just couldn't keep up with the lighting.
I expect the K5 to be at least as good as the 7d for noise and if they can pull off a large improvement in AF that would be a plus. I really like the pentax control scheme. If the K5 comes in at 1200 dollars or less it will be a winner even if the AF is not as fast as the competition. Not everyone needs a sports camera and the K5 looks a lot faster than the K7 which would capture fast shots just without as many keepers as a faster AF camera.
10-12-2010, 09:21 PM   #9
JohnBee's Avatar
QuoteOriginally posted by PinarelloOnly Quote
ISO 1600.
If you limit yourself to ISO1600 then I see no reason to consider the K-7 to be anything but an above average camera.
However, if high ISO shooting is your game then I would consider the K-x or the K-r and ultimately the K-5 systems.
PS. my experiences show that the K-7 holds-up nicely up until ISO2000 after which the level of effort increases as sensitivities move-up. However, that's not to say that the camera isn't usable past that level either.
10-12-2010, 09:33 PM   #10
QuoteOriginally posted by LeeRunge Quote
In my opinion, this "result" is such aggressive NR that the image looks a little like a computer generated drawing. I suppose that is the only option we have these days with high ISO... but I prefer a camera that will retain fine details, and allow me to decide which details I would like to obliterate into watercolour-dom .
10-12-2010, 09:59 PM   #11
LeeRunge's Avatar
QuoteOriginally posted by paperbag846 Quote
Not true on the "smudge" The 7d I own retains a ton of detail at 6400 it's in another league vs K7 at that iso. If you set noise reduction to "strong" you will get some smudge but I typically leave it disable or on low and it takes great shots at high ISO. The K7 has a lot of chroma noise as well and more detail loss that what I'm getting out of my cameras.
You can ring out good results with K7 but not past 3200 imo. K7 is a really good camera and it cost half what my 7d did as well. Also the "soft" images from 7d are rectified by adjusting the in camera sharpening. When that is made the 18mp comes alive and its a pretty noticeable difference in detail. Most review sites just give you strait ooc camera results and never shoot the potential. For example K7 got smashed on ISO when you can actually get pretty good shots if you take the time to pp well. Same for 7d getting the "soft" image reputation. Every camera needs some getting used to to get the most out of it.
I can post examples between both and you can see the detail difference in the 7d vs the K7 sensor. It has a 4mp advantage in resolution so one would expect better detail. The K5 is addressing the ISO issues of the K7 head on and that was one of two negatives I had with the camera. The other being AF which is tough to evaluate without having a review camera.
10-12-2010, 10:26 PM   #12
In general a lot of people are too obsessed about pixel peeping. Sure K7 has noise at 1600 but for my modest needs I find it perfectly acceptable with a little pp...
Here's a window shopping photo taken in beijing...
IMGP2105 | Flickr - Photo Sharing!
10-12-2010, 10:32 PM   #13
LeeRunge's Avatar
QuoteOriginally posted by Yassarian Quote
This is very true. Most prints I make are 8x10 or less and you can't tell what camera they came from nor would anyone even care to wonder for the most part. Same with internet posting. A p/s other than dof would produce the same results most of the time.
10-12-2010, 10:38 PM   #14
JohnBee's Avatar
Heck most P&S end-up looking sharper online, than DSLR's in most cases.
10-12-2010, 10:54 PM   #15
QuoteOriginally posted by JohnBee Quote
Hihihi...most P&S don't allow the user to change the sharpening...and , yes, they are oversharpened.
Sharpening is actually just an optical trick, There is NO additional data in the photograph.
Sharpening works because our eyes and brain perceive detail by looking at outlines. When the contrast at either side of an outline boundary is increased, the eyes "see" the boundaries more clearly. This additional processing is typically just a few pixels thick.
Extend that to the entire photograph, and you "see" more detail.
camera, dslr, iso, k7, photography
K-7 high ISO vs K20D high ISO supa007 Pentax DSLR Discussion 72 05-10-2010 04:24 PM
Need advice for high ISO shooting w/K20D klh Troubleshooting and Beginner Help 16 12-13-2009 04:14 PM
K20 high iso opinions!! COULDBE2 Pentax DSLR Discussion 4 07-03-2009 04:39 AM
How to reduce high ISO noise while shooting PentaxPoke Pentax DSLR Discussion 21 05-17-2008 07:17 AM
Night photography with K10D - High ISO short exposure VS Low ISO long exposure pw-pix Pentax DSLR Discussion 10 02-03-2008 01:37 AM
All times are GMT -7. The time now is 03:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
