Originally posted by Lazar The cheapest (yet good) solution I have found is to use the "Dooin USB2.0 Media Manager" (a $45 HD enclosure):
USBGEEK.COM
Just buy a 2.5'' IDE HD and put it in and you have a portable, cheap, light and fast way to copy your pictures directly form the memory card.
The enclosure has a Li-ion rechargeable battery, but you can also buy this "$5 External Battery box" and use AA batteries:
USBGEEK.COM
Btw, the Dooin USB2.0 Media Manager is faster than the Digimate III (I compared them with the same HD).
Last thing: K10D's raw files are also supported.
Well, since I already had an extra hard drive and it seemed oriented towards the DIY'er, I finally decided to purchase the Dooin iDo Photo Bank (Media Manager)
sold here for $45.00 (US).
The iDo Photo Bank (hard drive not included) comes with built-in battery, 110-240v charger, USB 2.0 cable, leather case, small screwdriver, and instructions (only in Chinese). Any standard 2.5-inch laptop hard drive should work with the iDo Photo Bank. An optional 4x AA-size battery pack ($5) provides longer run times. The iDo Photo Bank supports SD, MMC, CF I/II, xD-Picture, MicroDrive, Memory Stick, Memory Stick Duo, Memory Stick Pro, and Memory Stick Pro Duo media.
The installation of the hard drive was easy and everything is working well so far. Since the need to store images while traveling is relatively rare (used only occasionally for this purpose), I'm also using it in the meantime to quickly transfer larger groups of files between my various computers. The battery obviously means one less cord to connect while doing this.
stewart
UPDATE (11/29/07): Two individuals have reported problems after formatting the hard drive in this device using the NTFS file system. The device will not copy image files from the SD card afterwards. Because of that, I now recommend using the FAT32 file system when formatting the hard drive. Of course, Windows XP and later does not provide a means to format on a hard drive larger than 32GB using FAT32. Therefore, I also recommend using hard drives smaller than 32GB unless you're familiar with the workarounds for the FAT32 limitations within later operating systems.
Since the iDo Photo Bank does not include English-language instructions, I'll provide a quick overview (based on my own experences) below. If you decide to purchase one, you may want to copy this, edit it as needed in a word processor, and print the results for future reference.
OPERATING INSTRUCTIONS
INSTALLING THE HARD DRIVE
1. Place the iDo Photo Bank face down of a protected surface to prevent scratching the display.
2. Locate the four feet on the bottom of the iDo Photo Bank. These feet are actually small reusable plugs. Insert a knife or similar sharp instrument under the lip of each foot and lift upwards until the plugs can be removed with your fingers. Store the plugs in a safe place.
3. Using the provided screwdriver, remove the four screws located in the holes previously containing the feet. Store the screws in a safe place.
4. Remove the rear section of the case by lifting straight upwards.
5. Handle the hard drive ony be the sides. Do not touch the electrical surface on the bottom or press firmly on the top. Likewise, do not touch the electrical pins on the front edge of the hard drive.
6. After laying the hard drive flat in the iDo Photo Bank, align the hard drive pins with the socket on the iDo Photo Bank and firmly slide the drive upwards to insert the pins into the socket. A slight rocking from side to side may ease insertion. When aligning the drive, ignore the small group of pins located on the far left of the drive. Only the main group of pins are needed for the iDo Photo Bank to work properly. Be careful not to bend any of the electrical pins.
7. After checking your work, reinstall the case, screws, and feet.
Note: Before copying image files to the device for the first time, the newly installed hard drive should be reformated using a computer. Instructions included below.
CHARGING THE DEVICE
1. Plug the charger into the wall outlet and then insert the plug into the bottom of the iDo Photo Bank.
2. After several minutes, the battery indicator will appear in the display. The indicator will flash while the iDo Photo Bank is charging and remain lit without flashing when the iDo Photo Bank is fully charged. The initial charge will take about 4 hours, with subsequent recharge cycles requiring about 3 hours. The iDo Photo Bank is not harmed by leaving the charger plugged in after the battery is fully charged, but should not remain plugged in for periods exceeding about 24-hours.
Note 1: If the battery indicator does not appear after about ten minutes, insert a small paper clip into the "reset" hole on the bottom of the iDo Photo Bank and press once gently. If the display still does not appear, you may also need to press and hold the "PWR" button until the display flashes. At that point, the indicator should appear.
Note 2: If the battery in the iDo Photo Bank drains fully during operation, the iDo Photo Bank will turn off without finishing the operation. Any image files on the card will remain unaffected until deleted by the camera. After each copy operation, before deleting images with the camera, you may want to check the battery level in the iDo Photo Bank. If the battery level is especially low, you may want to retain the image files on the card until the iDo Photo Bank is recharged enough to allow uninterupted operation.
OPERATION
The iDo Photo Bank has two primary operating modes; a media card copier and a normal hard drive when connected to a computer.
Card Copier Operation
1. Press and hold the "PWR" button to turn the iDo Photo Bank on.
2. Insert the media card into the proper slot on the sides of the iDo Photo Bank. The slots are marked to indicate which card fits into each slot.
3. When the card is inserted properly, the "copy" symbol in the display will flash. The display will show the estimated percentage of hard drive capacity remaining. Press the "COPY" button to start copying the contents of the card.
4. The iDo Photo Bank will turn off after the card contents are fully copied. The card can be removed and returned to the camera.
Note: Contents from multiple cards are added to the existing image files stored in the iDo Photo Bank. The contents of the media card are managed by the camera. After copying the contents to the iDo Photo Bank, the images may be erased from the card using the camera. The camera is also used to format the card.
Hard Drive Operation
1. Connect the USB 2.0 cable to both the iDo Photo Bank and computer.
2. Turn the iDo Photo Bank on. With most supported operating systems, the computer will automatically recognize and install the hard drive (no drivers required). Moving the image files from the device to your computer is the same as moving files on any standard hard drive. Refer to help files for your operating system to discover how to move and copy files. Image files can also be deleted from the hard drive using your computer.
Note 1: Windows XP/2000-SP4/ME, Mac OS 10 or above, and Linux 2.4 or above, are supported. The iDo Photo Bank should also work properly with versions of the Microsoft Vista operating system, but that has not been tested. Mac OS-9 and Win98 are no longer supported by the latest versions (no drivers available).
Note 2: Before copying image files to the iDo Photo Bank for the first time, the hard drive should be formated using a computer. To do this in Windows, right-click on the hard drive icon and select "Format" in the pop-up menu. Both Fat32 and NTFS are supported.
(note - see updated infomation above)
Note 3. Supplemental power is provided by the USB port while the iDo Photo Bank is plugged into the computer. While this may allow increased operating time, it is not sufficient to prevent the battery in the iDo Photo Bank from eventually draining. When the iDo Photo Bank is turned off (using less power), the USB port can be used to recharge the iDo Photo Bank.
OPTIONAL EXTERNAL BATTERY PACK
The external battery pack holds four standard or rechargeable AA-size batteries. The external battery pack allows increased operating time. When the iDo Photo Bank is turned off (using less power), the battery pack can also be used to recharge the iDo Photo Bank.
