I received my K-5 today, along with the 16-50mm f/2.8 and 50-135mm f/2.8. First, a couple of impressions from a Canon shooter (5D Mark II):
- The K-5 and the Pentax lenses are light. In fact, compared to Canon and Nikon lenses, they are small and very light. This is very nice, as it will allow me to carry a few more lenses in my bag, while staying lighter than my Canon gear.
- K-5 build quality is very good. As you may or may not know, the 5D Mark II, while a very nice camera, isn't the most robust camera, and doesn't fare as well in the dust/moisture department. The K-5 is built like a tank in comparison, while also being smaller/lighter.
- Along with the lenses being smaller and lighter, the Pentax lenses are also a lot cheaper than their Canon/Nikon counterparts. That's a real advantage, as it means not having to break the bank when purchasing a new lens.
- In-body stabilization is great!! It's nice knowing that every Pentax lens will automatically gain this functionality. Image stabilized lenses are much larger, heavier, and more expensive.
- AF performance. The AF performance of the K-5 absolutely kills the AF performance in compared to my 5D Mark II. Using the two lenses in question, the AF is fast and accurate. It's also nice that I can make use of the outer focal points of the K-5, which is sometimes a problem with the 5D.
- Low-light performance. Here, the 5D Mark II beats the K-5 pretty handily, which is to be expected, given that the 5D is a full-frame camera. However, the K-5 is no slouch. For a smaller sensor camera, it does a great job in low-light, and as long as you can nail the exposure correctly, noise isn't a big problem up to ISO 3200, and even ISO 6400 can produce a high-quality image with a little help from noise reduction software like Noiseware.
- Color - Based on what I've seen, the rendition of color on the K-5 is more natural than on the Canon. The K-5 also handles reds and yellows much better. Shooting a red rose, even in cloudy conditions, on the 5D Mark II has a tendency to blow out the red channel. In the past, I've had to dial exposure compensation way down, and been very careful in how I shoot red and yellow flowers. Shooting the K-5 today, it was nice not to have to worry about this. The metering was pretty effective in most scenes, though it does seem to underexpose by about a third of a stop in some situations.
- RAW - I like that you have the option to shoot in standard DNG format.
Those are my first impressions, which are very favorable as you can see. The K-5 is the first APS camera that I've used in a long time that I feel has excellent image quality without a lot of compromises. The last APS camera that I felt this way about was the Canon 40D, released way back in 2007. Pentax has done a nice job with the K-5.
Here are a few images I shot today, just to put the K-5 through some initial testing. I plan on getting out later in the week to shoot some more interesting subject matter, and am looking forward to seeing how it performs.
With this last shot, I wanted to see how the camera would do in a more low-light situation. I think it did pretty well.
