Just Acquired new Transcend Class 10 16gb cards and decided a test was in order.
Setup:
- K20D with DA*50-135mm
- Manual Mode, Manual Focus
- 1/500th at f2.8
- Bench mounted, Artificial light
- Continuous Shooting-HI
- 30 Sec of shooting
Each Test was run 3 times. Cards were formatted in camera before each run.
Results:
Brand | Class | Size | No. of Shots | Time till buffer clear(sec.)
Transcend | 10 | 16gb | 30 | 24
Transcend | 6 | 16gb | 28 | 26
Kingston | 4 | 8gb | 27 | 30
Mushkin | 10 | 32gb | 21 | 35
Conclusion:
The class 10 Transcends showed a mild improvement over the class 6 Transcends which were slightly better than the class 4 Kingstons. The poor performance of the class 10 Mushkins was surprising but may be due to thier size and not slower write times. The new class 10 Transcends were fairly cheap on an Amazon Gold Deal at 12.52 USD each and free shipping (with prime) so I believe they were a good value. I may be up against the limit on the write speed of the K20D but still may try for better performance with the Transcends 150x or SanDisk Extreme series. Also, I am waiting to hear back from Transcend on the compatability of their new class 10 Wi-Fi cards for the K20D and that may be my next purchase.
Any recommendations or discussion on this topic will be appreciated.
Reason: Correct for <table> not working
