Hey guys im really sorry but i'll be very direct because im really at loss here..
i was photographing a festival and my k20d just died.. i pressed the shutter release and nothing happened...
i though i'd ran out of battery but it wasn't, i took the battery off and put it back in, it turned on but no shutter release.
i knew i had a card with the debug mode enable files, so i enabled debug mode and tried the switch test and the shutter switch is working fine..
i then started looking for all sorts of problems and i noticed one thing even under the heaby bass that was going on...
every timei pressed a button, any button.. i felt the camera shake and give out that peculiar sound it gives when you're in live view and have the shake reduction on
and when it goes away the action is performed.
(you hit play to see your last shot for instance... (...
) and it:
shakes, lags, show's shot.
you press the button again, and it does it all over again, peculiar noise and lag, when it ends, the action is performed..
i deciced to "downgrade" so maybe by some strange weird fault could set anything wrong with the firmware, i decided to "downgrade - upgrade"
and it behaves the same way
anyone can shed any light on this? i'ts so ironic, about a month ago i saw the shutter release count and it was about 45.000
i am so sad, i lost one of the most amazing shows ever in terms on light composition, it was, for me, my best opportunity ever to get beautiful unique pictures in my own way
but the camera didn't let me.
i started already making all kinds of scenarios because i can't afford a repair or get a nwe camera, so i started thinking how could i fetch for my two beauty not so rare primes
so that i could get a ist*D and use the kit lens!
if anyone can help me trying to figure out whats wrong with the camera...
sorry for broken English its not my native language
