04-12-2008, 10:13 PM   #1
K10D - So debug gone at 1.3? Any way to adjust AF?
The K20D allows you to adjust your AF settings on a lens-type or all-lens basis. I understand that the K10D used to have this "available" as part of the debug mode...which has been disabled at 1.3.
I have three questions:
1. Can you downgrade 1.3 to 1.0 (or whatever version you need to use debug mode)?
2. If you CAN downgrade and make the adjustments, do they stick if you upgrade to 1.3 again?
3. Is there any other way with the K10D to make the AF adjustments? After all, they are available in the K20D without sending the body away to service.
Thanks!
04-12-2008, 10:40 PM   #2
Nevermind...found RiceHigh's instructions on his blog.
04-13-2008, 04:32 AM   #3
QuoteOriginally posted by ksignorini Quote
I sent mine in.
Sent it back.
Still waiting.
Dave
04-13-2008, 04:55 AM   #4
I can't figure why so many things have been removed in the firmware I upgraded from 1.00 to 1.20 as soon as i got it, did I do right ? I've never really had any issues with the autofocus though
04-13-2008, 08:24 AM   #5
All YES!
Yes. See below for the steps:-
RiceHigh's Pentax Blog: How to Get Back to an Older Version of the Firmware?
Yes!
Yes! You can adjust the hardware screw settings which physically change the position of the AF module. But TRY AT YOUR OWN RISK:-
RiceHigh's Pentax Blog: Focus Calibrations for (Pentax) (D)SLR Bodies and Lenses
adjustments, af, camera, debug, downgrade, dslr, k10d, k20d, photography
Anyone use K10D at debug mode? rosier19 Pentax DSLR Discussion 25 12-18-2010 07:34 PM
Samsung GX20 Debug Mode Focus Adjust Webmonkie Pentax DSLR Discussion 5 05-26-2010 12:14 AM
K10D doesn't trigger shutter after debug mode Marcoz Pentax DSLR Discussion 7 02-18-2009 11:27 AM
K10D debug, few Qs axl Photographic Technique 2 02-03-2009 08:22 AM
K10d-debug menu-IR possible? Bokeh Pentax DSLR Discussion 6 05-17-2008 05:54 PM
All times are GMT -7. The time now is 11:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
