Originally posted by OPTMEKX& Hello All,
For the last couple of days, I was playing with my 1.4/50 MM lens from my ME Super to work on my K100 but no success. I put the dial on M mode (manual) and play with the Av button and the aperture ring and the DOF lever as well but all I see is flashing Av on the top LCD panel and and flashing F in the viewfinder. I also went to the custom setting and set it to #2 but the same result. I am just wondering now if it is me or the K100 that I cannot get it to work. I really love this lens as it gives me excellent result on my ME. Any help will be appreciated. I also followed every instruction on this thread but I am going nowhere, the M mode though work just fine on my 16-45 DA lens.
Cheers,
Rene R
Hi Rene,
I just got home, so I'm playing catch-up here. Step by step...here we go.
So in Menu>Custom, you went to "Using aperture ring" and chose option 2.
Now you made sure your camera was off when you mounted your lens.
If you have SR on when you turn on your camera, the screen will ask for the focal length of your lens. Use left or right to choose 50, then press ok.
Go into M mode. This is the only mode I can get my M50/1.7 working.
You can change the shutter speed using the thumbdial.
Switch the focus mode switch (on left side of camera) to MF. I always forget that! I won't be able to fire unless I get a focus lock (hexagon in viewfinder) because the camera is programmed that way. MF will override that.
Hope that helps!
